Old 05-13-2003, 08:33 PM
gcookaustin
Torque converter locks/unlocks - really annoying
As I understand it, the torque converter will not lock until it reaches ~160 degrees F, and will unlock if it dips below 120 degrees. Ever since I got my new transmission, it seems as though the new algorithm is to lock if at 160 degrees and unlock if at 159 or something. In other words, after it first locks up it will subsequently unlock within seconds, and stay unlocked for a while, then lock back up once or twice before staying there. It's really annoying, why does it do this and is there a way to get it to just stay put?
Also, for the first few minutes after startup the engine braking seems really eager to kick in when letting off of the gas, then the RPMs pop back up again to coast. This is even more annoying. If I let off of the gas really slowly then I can get the car to slow down for a longer distance, but requires more skill than I can muster. Also if I let off of the gas and then accelerate the RPMs will first dip slightly (and slow down the car) before picking up and accelerating. This will even happen on the interstate with the TC locked up. It's split-second, but rather rough and annoying. Is there a fix for any of these, perhaps a new TPS?
Thanks,
Old 05-13-2003, 09:08 PM
alacrity024
just curious..
do you have an external tranny cooler?
Old 05-13-2003, 09:20 PM
gcookaustin
Re: just curious..
Nah, not unless the used rebuilt transmission that the warranty company sent already had one on it...is that possible?
Old 05-14-2003, 01:53 PM
mbtoloczko's Avatar
sans SVX
Re: Re: just curious..
Nope.
Mychailo
Visit my locker
Old 05-14-2003, 08:07 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
I had that.
It turned out to be a dirty TPS. What was happening was that the TPS was sending a signal that the computer interpreted as me flooring it so it unlocked the TC.
It only happened at cruising speed.
Check the ECU and TCU for error codes.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 05-14-2003, 08:24 PM
gcookaustin
Originally posted by mohrds
I had that.
Doug
I don't have any error codes from it. Did it happen all the time, or just during the first portion of your trip? After it does it a few times it settles down for the remainder of the trip.
Old 05-14-2003, 08:36 PM
mohrds's Avatar
It would only happen when I first got to cruising speed for the first 10 minutes or so, then it would go away for 15-90 minutes, then come back for another 10 min, etc.
Doug
1994 LSi (4/93)
2000 Ford Excursion
