Old 05-13-2003, 09:53 AM
want-a-fast-svx want-a-fast-svx is offline
Send a message via AIM to want-a-fast-svx
K & B spring rates
anyone know the spring rates of the k&b springs that dayle has???do the struts and springs that dayle sells require any welding or special modifications like the koni/gc??just curious..thanks for any help
Old 05-13-2003, 10:33 AM
GreenMarine's Avatar
GreenMarine GreenMarine is offline
From POST-***** to LURKER
Not sure but I think they are about just like the Ground Controls... Yea, they will probably require welding unless you can find a company that makes kits with K&B springs....
2020 Subaru Outback Touring - Wife's first Subaru
2005 Volvo V70R - 5-cylinder love! :Heart:
** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned
** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!!
** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love...
Old 05-13-2003, 10:48 AM
so is the koni/gc setup probably better then???
Old 05-13-2003, 11:39 AM
That's the setup that I've herd the most about... I'm trying to be a lone ranger though and am still hunting down Aragosta.... I'm gonna get what I want from them!!!!
Old 05-13-2003, 01:55 PM
Porter
The K&B don't require any cutting or welding... they are a direct replacement for the stock springs.
The Ground Control kit is using a universal fit spring, that's why you have to cut/weld the strut housing, and it must be used with Koni struts.
The K&B can be used with the stock struts just fine... so the K&B is a much cheaper alternative. A full Ground Control / Koni setup will run you about $1000 just for the parts.
Old 05-13-2003, 02:53 PM
so what if one was to get the k&b springs and then koni struts would that be a decent upgrade or no???not feasible???thanks for any help
Old 05-13-2003, 11:07 PM
I have the Koni struts and K&B springs and it was a great upgrade. It lowers the car and it corner far better than when it was stock.
Old 05-14-2003, 08:15 AM
did you install them yourself???if so how hard of a job was it???thanks for any help...
Old 05-14-2003, 09:21 AM
Sorry - they were already installed when I bought the car.
Old 05-14-2003, 02:26 PM
mbtoloczko's Avatar
sans SVX
Re: K & B spring rates
The K&B springs are advertised as lowering springs. According to this website:
http://www.sissk.co.jp/kbsports/subaru/subaru.htm
The spring rate is somewhere between 10 and 20% higher. They are in a completely different realm than the GC springs which are about 250% stiffer.
As the other people said, they are a drop-in replacement for the stock springs and will work fine with the stock struts.
Mychailo
Visit my locker
