Headlight Help Please Quick
Alrighty guys and gals i have the drivers side headlight apart and sanded the outside...i only have meguiars plastic cleaner im confused as to what the heavy and medium cut cleaners are???and where do i get them cause with just the plastic cleaner the headlight still looks scratched???is this normal???also do i sand the inside or just use the "cleaners"???sorry just dont want to screw the lights up..thanks in advance for the help hopefully they turn out ok
Why did you sand it? The cleaner would have cleaned it up nicely without the use of sandpaper.
At any rate, I would try to use some sort of compound or something to try and reduce the scratching. mike |
i sanded it cause thats what the how to said to i just figured that was the best way...ruh roh...did i %##@ up???
The plastic cleaner won't cut enough to remove the scratches from sanding. You need something with a little more bite. If you can't find the heavier cut plastic cleaners, you should be able to use fine-cut rubbing compound, then polishing compound, then your plastic polish. Doug
i went up to the 1500 grit but ill go look for the plastic cleaners now...thanks for the help so fast
i truly appreciate it |
thats what i did i went from 350-400-600-800-1500....i didnt have a 1000...do you by chance remember any names of the cleaners that were used, adn where i might be able to find them??thanks for the help again
L
do you think the mothers is enough of a cleaner???should i try something else???thanks again for the help
L
Doug
I think they must have changed the makeup of the plastic on the lenses at some point or another throughout the run. My lights had no chips at all after 130k miles of driving in PA. The ellipsoids also didnt chip at all... hmm.
Mike |
All the lights are the same. You may want to also consider in taking out thew fog light flute if you have them apart. Wet sanding using the stages of sand paper (300-1500 grain) will get you the best results. I use Janvil plastic cleaner and a buffer on a drill as a final step.
