Old 08-15-2010, 10:43 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
EZ36 swap
has any one tried or thought about this swap ?
I has teh FWD LS-L
Old 08-15-2010, 11:36 PM
subbieatnz's Avatar
subbieatnz subbieatnz is offline
Re: EZ36 swap
One guy that was on this site was thinking about it.. Cant remember who it was...
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired
1989 Vortex 6 Maroon
1983 RX Silver Grey
1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration
Old 08-16-2010, 08:03 AM
NeedForSpeed NeedForSpeed is offline
Re: EZ36 swap
Other than the marvelous 250,000 miles on your 4.111 [like those too!] SVX, is there another reason for you to consider the EZ36, other than lighter, more compact, etc.?
Someone with skill would have to take on that swap, wiring, computer, etc., but, it would be interesting .
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 08-16-2010, 11:06 AM
sicksubie's Avatar
Re: EZ36 swap
very nice tq curve, 10-12lbs off the nose of the car, smaller (easier to work on while in the car)... All pretty good plusses, but I dont think it is worth the time and effort yet. Maybe in 5 years as EG33's get scarcer and EZ motors become cheaper...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 08-16-2010, 11:13 AM
Re: EZ36 swap
Not to mention the better front to rear weight distribution, as the EZ is not only lighter, the engine would sit back farther .
The question is, if someone had an EZ engine, is the swap possible? What would it take make it happen, to wire it?
As it stands now, no one has perfected the Phase II 4EAT swap, as far as I know anyway, and I don't know that much .
Old 08-16-2010, 11:52 AM
sicksubie's Avatar
Re: EZ36 swap
It would be easier I would imagine as with the Phase II trans swap you are mixing and matching different generations of Subaru management systems. If you did an EZ36 swap then you would want a current generation transmission and TCU as well ( or keep it simple and go manual). That way the ECU and TCU are staying mated as they were from the factory. The hardest part would be working out the harness through the SVX body...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-16-2010, 12:07 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Re: EZ36 swap
Another complication is that the new ECU's are tied into a chip in the key. So you would either need to also change out the ignition switch/harness or hack the ECU.
And I think Bobby is right about swapping the engine and trans together. The hardest part of the Phase 2 tranny working with the EG33 was figuring out the comunications between the EG33 ECU and the 2003 TCU.
Old 08-16-2010, 01:18 PM
sicksubie's Avatar
Re: EZ36 swap
Meh, that's a good excuse for a push button start...
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 08-16-2010, 01:39 PM
Hocrest's Avatar
Re: EZ36 swap
From what I've heard, the code on the key is needed by the program on the ECU. So even with a push button start like they have in Kia's, you would need to have a properly coded key tied into the harness some where.
Old 08-16-2010, 02:34 PM
Re: EZ36 swap
'was figuring',,,, past tense?
Was this completely figured out, how to run a Phase 2 trans?
Old 08-16-2010, 02:51 PM
Hocrest's Avatar
Re: EZ36 swap
Yeah, past tense. Tom spent hours with the FSM's determining what was needed between the two computers. And then we spent a few weekend sorting out and splicing all of the wiring.
Old 08-16-2010, 02:58 PM
Re: EZ36 swap
I knew that you guys were working on it, last mention that I saw was that it was running, but that there was still something left to sort out?
Is that the same path that would allow a 5EAT to be installed, could it be done knowing what you guys know now?
Old 08-16-2010, 03:37 PM
92_LSL's Avatar
Re: EZ36 swap
would the transmission from an ez30 legacy work with an ez36 ?
I has teh FWD LS-L
Old 08-16-2010, 07:26 PM
Hocrest's Avatar
Re: EZ36 swap
She's been driving it for about 18 months now...
Yeah, same basic thing. But the 5EAT/VTD has much more wiring and additional sensors that would need to be sourced and wired in.
Old 08-16-2010, 09:14 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Re: EZ36 swap
The EZ36 is also a motor with unusual internals and is not one that can be modified cheaply if future plans soar. The motors uses offset connecting rods to achieve the correct rod ratio with the increased stroke. Good motor for what it is, but not really the best candidate for a swap. I'd stick with the 30/30R motors. Far more "adaptable" in the long run than the 36.
