90 Legacy flywheel on SVX?
Does it fit?
92 Ebony - Level 10/n2o REAR-ENDED 92 Teal - painted yellow/4.11 5spd/n2o SOLD 92 Claret - 4.44 SOLD 94 Barcelona - FWD SOLD 92 Ebony - 3.90 SOLD 94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims |
Re: 90 Legacy flywheel on SVX?
Thanks Randy
Actually, its for my 5 spd swap. Flywheels are hard to come by in these parts.
Re: Thanks Randy
why not get a lightened flywheel, if you need a new one... it'll help performance too
SV What? |
Are you buyin'
There is quite a difference between $60 and $450. I also like the smoother shifts provided by the heavier unit. I haven't driven one with either, so I am just speculating. Any input is very much appreciated.
Is there any reason not to use a '90 flywheel? Does it take the same clutches as the later ones?
The 90 Flywheel will work fine, I don't think there is any differance in any of the 90-up manual flywheels.
Well I got one for $50. It weighs about 18 lbs, so maybe there is some differences. I measured the friction surface and it is 225 mm like the others. So maybe I ended up with a light flywheel afterall.
Oh yeah, and I got all the pp and crank bolts too. Thanks for the tip, Huck.
that sounds like a light one.... they're usually in the 25lbs range...
SV What? |
