EZ36 swap
has any one tried or thought about this swap ?
I has teh FWD LS-L |
Re: EZ36 swap
One guy that was on this site was thinking about it.. Cant remember who it was...
1992 NZDM SVX Maroonish Red/Black ( 1st car ive owned with an cd player ) Has been retired 1989 Vortex 6 Maroon 1983 RX Silver Grey 1973 1400 GSR Yelo 2 Door Coupe awaiting Restoration |
Re: EZ36 swap
Other than the marvelous 250,000 miles on your 4.111 [like those too!] SVX, is there another reason for you to consider the EZ36, other than lighter, more compact, etc.?
Someone with skill would have to take on that swap, wiring, computer, etc., but, it would be interesting .
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Re: EZ36 swap
very nice tq curve, 10-12lbs off the nose of the car, smaller (easier to work on while in the car)... All pretty good plusses, but I dont think it is worth the time and effort yet. Maybe in 5 years as EG33's get scarcer and EZ motors become cheaper...
Re: EZ36 swap
The question is, if someone had an EZ engine, is the swap possible? What would it take make it happen, to wire it? As it stands now, no one has perfected the Phase II 4EAT swap, as far as I know anyway, and I don't know that much .
Re: EZ36 swap
It would be easier I would imagine as with the Phase II trans swap you are mixing and matching different generations of Subaru management systems. If you did an EZ36 swap then you would want a current generation transmission and TCU as well ( or keep it simple and go manual). That way the ECU and TCU are staying mated as they were from the factory. The hardest part would be working out the harness through the SVX body...
Re: EZ36 swap
Another complication is that the new ECU's are tied into a chip in the key. So you would either need to also change out the ignition switch/harness or hack the ECU.
And I think Bobby is right about swapping the engine and trans together. The hardest part of the Phase 2 tranny working with the EG33 was figuring out the comunications between the EG33 ECU and the 2003 TCU.
