Old 06-09-2003, 02:53 PM
Mr. Pockets's Avatar
Moderator
Funny engine noise
This might be just my paranoia, but in case it's a sign of something serious, I'll ask you guys about it.
I noticed that when my SVX idles, it makes a cyclic noise - like a RRRrrrrrrRRRrrrrrrRRRrrrrrrRRR sort of noise. It idles at a normal speed, and the revs don't lope up and down perceptibly, but it's making a noise like it is. A/C was off and I had the car in the garage on jackstands - I had just hooked the transmission cooler back up and wanted to make sure it didn't leak before I put the bumper back on.
Any ideas?
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 06-09-2003, 04:05 PM
svxeno
Mine did that after the ECU had been without power for a while. It settled down in a day or so.
Hope that helps.
Randy ii
Old 06-09-2003, 05:11 PM
Beav's Avatar
Beav Beav is offline
Not as old as Randy
Use a long screwdriver or similar (a stethoscope would be good ) and listen around the front cover of the engine. You may have an idler, tensioner, alternator, p/s pump or a/c comp. bearing going bad.
