cats and gas mileage
A guy here at work who was a mechanic for some time was talking to me about catalytic converters and gas mileage. It started with him saying that I should be careful with removing cats because it messes up the fuel air mixutre. He said that normally, the heat from the cats burns up excess hydrocarbons and your O2 sensor gets the "correct" reading that way. Once you cut the cats, the hydrocarbons go to the O2 sensor and plug it up and give it a bad reading. This doesn't really make sense to me, though, because our O2 sensors are upstream from the cats. Does anybody else know why cutting the cats would hurt gas mileage?
Time for my very own long list of mods: 92 SVX LS-L - Ebony Pearl - 2002 WRX 5MT trans w/STi gearset (rebuilt & installed myself ) - BMW E46 HID retrofit - Kenwood Headunit - Phoenix Gold 75x4 RMS amp - Alpine Type R 6.5" front components - Alpine Type R 6x9 3way rear speakers - 18"x9" Rota G-Force wheels w/225/40ZR18 Toyo T1R's - Mychailo's custom springs - Urethane front & rear sway bar bushings - KC exhaust (2.5" dual magnaflow) - Escaine seat swap - Removed Spoiler I don't care if Subaru says it's STI...it will always be STi to me |
You are correct. On pre-OBD-II SVXes (before 1996), the two O2 sensors are in front of the cats. Their purpose is to monitor the amount of unburnt fuel in the exhaust stream, and relay this info the the ECU. On OBD-II SVXes, there is a third O2 sensor in or just after the third cat. This O2 sensor is used for monitoring the condition of the emissions equipment.
Cat-astrophic
I have said it before on the boards, Yahoo! and here, it is a bad thing to remove the cats.
The cats do away with unburnt hydrocarbons, as your friend said. Your unleaded fuel has a loads of complex hydrocarbons added to do the job lead salts used to do before, stop your fuel from pre-detonating or "pinking" as we call it, and damaging your engine. These complex chemicals have many known carcinogens in them, and the reason they are allowed in gasoline is because it is presumed your cat will burn them all up. Which is why your car needs to pass emissions testing. You take away the cats between tests, and your engine is pumping unburnt carcinogens into the street. Does not display much concern for the health of your fellow man, woman or child in the street. To anyone contemplating removing the cats, I say, grow up, get your few extra horsepower some other way besides poisoning people. Joe
I still get 25-26mpg with no cats on highway. My wife can get 27 pretty consistently in my car but she has a lighter foot than me. I get 19-22 around town. My mileage did not change at all with the exhaust change. If I had known it wouldn't change I'd probably have left them on. Either the stock system flows very well or my butchered system isn't very efficient.
my obs, has had the post cat O2 sensor sheared off for quite some time, and the milage hasn't gone down at all, and it's not sensing anything at all.. (except the lack of o2 sensor and cel)
as to passing emmissions removing the 3rd cat from the svx and leaving the 2 initial cats will probably still pass emmissions IF you live in one of those crappy places that requires emmissions, i, do not i passed inspection on the obs w/o the o2 sensor at all
SV What? |
First off, just because you don't have cats dosn't mean your car won't pass emissions. My SVX passed emissions with no cats and my freinds 302ci Ranger passed with no cats, on the dyno! As for the 3rd O2sensor it's only there to make sure the cats are working, it dosn't effect the way the vehicle runs at all, and with a lot of the new emissions tests OBD II cars will just be checked by pluging into them with a scan tool and checking for codes. So if you CEL is on it's going to fail.
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
you can hook an resistor inline with the 3rd o2 sensor to fool it into thinking it is working
SV What? |
