Old 05-13-2009, 06:03 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Need some electrical harness gurus inside
I'm in the process of swapping that EG33 into my 2002 WRX rally car, and I need to thin out the SVX harness to the bare minimum required to run the engine.. It's been so long since I even looked at the harness from the SVX that I have forgotten what is what. I would like tostart by just cutting out any clips and related harness that 100% definitely have nothing to do with the PCM and related functions.
Below I have taken pictures of all the electrical clips. This is the main harness under the dashboard of a 1994 SVX.
If you gurus could assist me in labeling as many of these clips as possible it would help me out tremendously. The pictures are numbers as s1- s18,so just replay by saying soemthing like s4 = radio harness, heater blower, etc.
Old 05-13-2009, 06:04 PM
Boxersix's Avatar
Re: Need some electrical harness gurus inside
Old 05-13-2009, 06:56 PM
Manarius's Avatar
Manarius Manarius is offline
S16 is part of the OBD system used for checking ECU codes.
-Jason
-Obi Wan Kenobi
Old 05-13-2009, 08:03 PM
redlightningsvx's Avatar
Collision Refinishing Tech
So are the plugs on S-17.
S-9 looks like the TCU plugs.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-13-2009, 10:07 PM
svxpert svxpert is offline
wow, you really need a FSM wiring diagram section. that would help you out immensely.
Liberalism is a disease. When you can stare at facts and ignore them anyway, you have it.
Old 05-13-2009, 11:44 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
S12 looks like what connects to the front wiper control module, but that could also be the large connector in S2.
You've repeated S1 in the second post.
Can you post a picture of the whole mess spread out (doesn't have to be completely "neat"). That might help folks identify portions.
There's a separate harness under the dash that connects to the instrument panel ("combination meter"), radio, speakers, clock, cigarette lighter, and a couple of other things. That doesn't appear to be in your pictures.
David C.
1996 Laguna Blue Pearl SVX L AWD
See my home page for SVX radio install/removal instructions and wiring harnesses
