starting problems
in short, occasionally when i try to start the car, the engine doesn't turn over at all
ill let the car sit for a couple minutes and then it'll start up right away and...idk if this has any connection with the problem above, but in the mornings when i start the car, the engine will turn and catch the first time, but then immediately die i start it a second time and its fine could this be because of a low battery? i really dont know
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
probably not
You can always...
...1) check the battery. An old wornout battery can do this a lot.
2) I've had a switch/ignition cyliner issue (for about 4 years) where if you wiggle the key a bit it starts every time. The shop suggested I needed a "new or rebuilt starter" at that time... Needless to say the car has been starting for the last 4 years so I didn't follow their advi$e. Cheers!
' 92 SVX @ 185K ' 91 420SEL @ 223K! ' 88 420SEL I. @ 178K (what a buy!) ' 87 F250 @ 180K ' 93 ZX-11D @ 29K ' 93 SC400 @ 93K 2001 Valkyrie Interstate @ 6.6K (Brynhild) Y2K NightHawk 250 @ 1,500 miles ' 88 420SEL II. @ 208K '85 F150 @ 135K |
A new ignition switch seems to have cured the intermittent, turn-the-key-and-hear-nothing problem for me.
dcb |
