Air Conditioning???
Air Conditioning???
There is no button for AC, so how do I make it work? First warm day outside and the vents seem to only blow warm air. I set the temp control at 65 (low as it goes) and its outside temp is 78. Still get just warm air. Inside the car feels like 85. Yet I still get warm air. Where do I start looking to fix this? Recharge AC system? Is there an internal temp sensor that activates the AC? I am new to this whole pick a temp automatic thing. |
Re: Air Conditioning???
My guess is on the recharge.
Trevor Avondale, AZ 1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13 1992 LS-L Claret 178k totaled 10/26/09 1987 BMW 325is 60% of the time it works, every time |
Set the Climate Control to the "Auto" setting and then set the temperature down to 65 degrees, put the fan on high. If it doesn't start blowing cold then it probably needs a recharge or some other maintenance.
Here is a document that will help. http://www.subaru-svx.net/photos/files/How-To/14349.pdf
Odds are that you'll need some $300ish part that needs replaced but a recharge will last a little while.
My A/C was broken for a while last year but I got it recharged. Charge lasted about three days before going back to warm so I had something else fixed but I can't remember what it was. Also got a charge and now I'm back to warm again.
Try getting all of the o-rings and seals replaced first, then recharge the sysem. You should be able to replace most of them pretty easily yourself. Get it recharged and it should be good to go unless some component of the actual system has failed. Also check to see that the compressor isn't seized and that it is actually engaging when you hit the "auto" button on the CC.
Yeah im thinking recharge it and see how far thats gets me.
I think the compressor is turning on, when I first hit auto with it set on 65 there is a noticeable sound difference and a current draw is heard in the fans for a moment. Back to learning how to use the auto temp thing. So setting it at 65 will force AC to turn on? I have had it on 65 since I got it, if I set it above 70 it seems to blow air out the heat vents under the dash only. Is there no way to turn the AC on high fan on without using auto? Will the AC kick on at temp setting of 65, even if the outside temp is below 65? |
When you have the system charged, have them listen for leakage from the compressor.... thats where mine was losing freon until I evacuated the system.
