*** Doing Rear Subframe Any Pointers ***
Bought most every bolt, washer, bushing, nuts and caps OEM
SSP should provide Rear subframe with trailing arms Going to ask for support plates New calipers Hopefully sway bar and brackets * Now as far as I know the frame is bolted to the body The axel shafts shouldnt have to leave the diff Nor the gas tank -prob use ramps, jack stands, etc. Do I have to remove the exaughst ? Will I need any special tools ? Do the bearings have to be pressed into hubs ? *Can I use clamps to rewind calipers and does proportioning valve need to be reset Pnuematically if reservoir goes empty ? Any knowledge would be welcomed thanks Tommy 1996 LS-I -Polo Green - #467 |
Re: *** Doing Rear Subframe Any Pointers ***
Same here. did this go anywhere?
Beware, the mounting bushings are most likely not available as parts..
I got my girl, I got my glass, I got my car and I'm ready to f... |
Have a whole rear suspension out of a doner car on the way
I bought all the bushings/ bolts left in the system around here through a dealer |
I bought a rear sub-frame from SSP a couple of years ago. It was in mint condition. It looked like it was removed from a new car.
1997 Bordeaux Pearl, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, |
SSP refused to sell me a subframe...
The mounting bushings were never separate parts. If they are worn, you need new ones and they are not available anywhere. Please check the condition of yours, the solution is not that expensive if we share the expense (Poly bushings).
True!! Thing is mint
Thread Tools | |
Display Modes | |
