#46
Easiest way to:
Insert image into personal locker from a URL. ........Find the image you want to put into your locker and right-click on it. ........Click on "Properties" in the drop-down box, the Element Properties box opens. Copy the location under "Image Properties" .......(should end in .jpg) ........Open the folder in your locker where you would like to put the image and click "Upload photo" ........Scroll down to Extra options at the bottom and paste the location you copied into the Retrieve all images from a URL: ........window. ........Click on the upload/submit button ........Once you see the thumbnail and the box Add Photo? is checked, just hit the Process button. Insert image from locker (or a URL) into a post: ........Basically the same procedure. ........Open the photo in your locker and right-click on the image. (or right-click on an image in a URL) ........Click on "Properties" in the drop-down box, the Element Properties box opens. ........Copy the location under Image properties ........Paste it (Ctrl + v) into the "Insert Image" link (yellow box with the mountain in it) in your post and that should be it. ........Also see my last post in THIS THREAD .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 11-25-2007 at 10:07 PM. |
