Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Other Mods
Old 08-24-2005, 03:55 PM
thundering02's Avatar
thundering02 thundering02 is offline
Giong back to the beaters...
Originally Posted by Jonesy
I've been considering th 5 speed swap for a while. What trans are you using, and what do you need as far as electrical?
Welder, impact gun, etc.
86 GMC Jimmy Blue and Silver- R.I.P.
87 Integra RS ~228k miles R.I.P.
92 SVX LS-L Perly ~186k R.I.P.
89 240sx se red ~165k miles Gone and unknown
89 240sx se Black~185k R.I.P.
85 Toyota pickup ~205k R.I.P.
85 BMW 325e ~ Gone and unknown
85 Ford Mustang getting engine swap now!
05 Colorado ~108k Daily Driver
Old 08-24-2005, 08:19 PM
I am using a 94 imprezza 5mt. It has 4.11 gears with a spec stage 2 kevlar clutch. People have certain things against the cabel clutch setup but I actually like it better as I have control over pedal positioning and actuation points. Not many people like where my pedals are but... I like it
TOm
Old 08-25-2005, 10:19 AM
Earthworm's Avatar
Meow!
Originally Posted by TomsSVX
Nitrous... Even 4.44 gears cannot give you an extra 75 hp.
Yeah, nitrous will give you a good bang...just ask Subafreak!
Old 08-25-2005, 11:59 AM
Jonesy
Do you guys run wet or dry and where can I find a good kit? I have a nitrous refil station at my work here... just found out today. So this could be a go. Is the nitrous hard on the tranny at all?
Old 08-25-2005, 12:22 PM
Earthworm's Avatar
Meow!
Dunno, never ran nitrous through the tranny before.</smartass>
Old 08-25-2005, 12:34 PM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Install a trans cooler, small car shift kit & change your ATF and you should be good to go!
-Chike
2006 Steel Gray WRX TR (sold)
Old 08-25-2005, 02:30 PM
Jonesy
lol, not the nitrous itself, but the extra power, on shifts. How big of a tranny cooler. I would imagine it would have to be fairly small, as there is not much room to work with.
Old 08-25-2005, 02:38 PM
Chiketkd's Avatar
As long as you plumb it in-line with the stock cooler, anything between a 10,000-25,000 GVW trans cooler would probably work fine (larger the better of course).
The trans cooler is typically mounted infront of the radiator. You have a lot of room to work with!
-Chike
Old 08-25-2005, 02:43 PM
Jonesy
perfect. I will probably pick up a trans cooler this weekend then. And the filter and then see what kind of kits I can find for the nitrous
Old 08-25-2005, 08:28 PM
A Zex 75shot dry would be perfect for someone trying to pick up some quick horsepower. I am looking to find a 100 shot wet and pick up a progressive controller for it so I don't kill my trans on launch
