SVXBot
View Poll Results: Preferences and opinions
Keep the JDM BBS wheels 8 100.00%
Go for the HYUNDAI wheels 1 12.50%
Don’t see any figment/ drivability/safety issues 0 0%
Have drivability, handling or safety concerns 0 0%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Old 03-08-2019, 12:08 PM
Pristine Green Polo Machine
Wheel opinion please
Having gone from the original stock wheels to the BBS JDM wheels, I am thinking about fitting 17” 2014 Hyundai Elantra Limited wheels onto the SVX.
I really like their design and have actually fit one from my Elantra onto the polo to check for tolerances. No issues.
They are 17” x 114.3, +52mm offset and 7” wide. Would I be able to use these on the polo without too much negative effect?
The closest size tire would be a 225/45ZR17. Specs are very close to stock and they should fit on the 7” wheel.
Opinions? I like the look of this wheel. Slightly angled spokes, but not so much that they look odd on the other side of the car.
1996 Polo Green LSi #216...137,900 miles...
JFICX8659TH100216JF1CX8659TH100216........Mfg. Date: 11/1995......... Service Date: January 2, 1997
HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, Raceconcepts dimpled/slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler.
R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a COW March 4, 2016
2014 Hyundai Elantra Limited ...97,000 miles. Actually quieter and smoother than the SVX
5th Registered Network member —2/21/2001
Old 03-08-2019, 02:58 PM
SoCoNoHa's Avatar
SoCoNoHa SoCoNoHa is offline
H6 Fanatic
Re: Wheel opinion please
Yeah looks better than I expected. I don't think I could live with the lack of symmetry from side to side though. I'm sure it's hard to notice, but I would know.
1992 SVX LS-L Pearl White - 5MT
Custom Short Throw/Group N trans mount
1995 Impreza 2DR
2002 Impreza 2.5RS
Last edited by SoCoNoHa; 03-09-2019 at 02:23 AM. Reason: I was blind but now I see
Old 03-08-2019, 03:57 PM
I see nothing! (in a German accent like Schultz)
That's the ticket! Danke schoen mein colonel.
1997 Bordeaux, 1992 Claret (parts car) 2011 BMW 535i GT Xdrive, 2006 Nissan X-Trail SE 4WD, 2012 Moto Guzzi Norge GT 8V, 1982 Honda Nighthawk 650 (sold)
Old 03-08-2019, 06:05 PM
Fixed the first post. On my PC, they showed up fine.
b
Old 03-08-2019, 10:40 PM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
IMO, I dont think they look good. BUT, to each their own.
1992 SVX LS- 103k built motor
2002 Park Avenue-165k intake, exhaust and tune daily driver
2017 Forester touring- 12k the old ladies daily
2003 Ram1500- 170k intake, exhuast, cam, solid lifters, tune 4.10 rear end- RIP stolen Oct. 2017
2008 328i convertible- 33K M3 style subframe bushings, front strut bar, thicker sway bars, magnaflow muffler, coco floor mats
Old 03-11-2019, 02:45 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
I like the Hyundai wheels; to me they are a modernized version of the stock wheels. They might even look better than the JDM BBS. Not enough so, though, in my opinion, to swap them out. If you do, though, they will look nice.
Old 03-11-2019, 04:20 PM
Terry,
Thanks for your opinion. I had the same thoughts about their design.
I was hoping to obtain a bit of technical insights about the effects on safety and handling with regards to putting a slightly narrower wheel on the SVX.
The tires I choose may be too big for that wheel. But going down to a 215/45R17 would have its own issues. Load rating, Speedo errors, contact area.
Larger wheels are usually wider.
JOHN
Old 03-11-2019, 04:45 PM
WYOSVX's Avatar
Technical insight will have to come from someone wiser than I.
I run 235/45 17 with no issues as far as I know. They are supposed to be the same diameter as stock or very close and you already know there is a diameter comparison chart somewhere out there, maybe one of the online tire sellers.
Sorry I don't have more technical info, I could only speculate.
I've never heard a complaint about tread contact area from anyone running narrower tires but that doesn't mean they didn't have any problems.
Old 03-11-2019, 07:02 PM
John,
Keep the BBS, much better than the Hyundai.
1992 SVX LSL 170k [I]4.44 Transmission, Ecutune TCU, Ecutune Stage 1, transmission cooler, silver STI BBS wheels, Sony Bluetooth double DIN head unit, Infinity front speakers, Lamin-X protected headlights
2010 Mazda 6 i Grand Touring - 120K
2007 Honda Odyssey EXL - 100K
2004 Mazda 3 S - 106K
2006 Mazda 5 Sold at 60K 2012
2005 Mazda 6i Sport Sold at 206K 2013 great car[/COLOR]
Old 03-12-2019, 08:43 AM
LarryIII LarryIII is offline
John,
I like the stock and BBS wheels better than the Elantra wheels. Also, Rosie says that the Elantra wheels are not bold enough for the SVX. But yours is the only opinion that counts. If you go with the new wheels, I would like to buy the BBS ones from you if you're interested.
'17 Tungsten Pearl Outback 3.6R Ltd...."AISHA"
Old 03-12-2019, 11:32 AM
Originally Posted by LarryIII View Post
John,
Larry, you really want to know?
http://www.subaru-svx.net/forum/show...&highlight=Bbs
Old 03-14-2019, 04:13 PM
John,
Did you get my reply to your PM?
Old 03-17-2019, 08:19 PM
WYOSVX's Avatar
For whatever it's worth:
Found this discussion on another forum about tire/wheel size. Might help a little, you probably know most of it and then some:
https://www.wrxtuners.com/forums/f53...ire-faq-19172/
He talks about the effect of width on suspension geometry, mostly more width.
Also, compared on a tire size comparison chart. Stock (per my door jamb plate) compared to the size you mention:
https://tiresize.com/comparison/
215/55 R 16 compared to 225/45 R 17. Diameter 25.3 to 25. Width 8.5 to 8.9. Sidewall 4.7 to 4. Circumference 79.5 to 78.4. Revs/mile 797 to 808.
I compared a bunch of other sizes based on research I was doing today because I have to buy new tires. I looked at other sizes SVXers are using to try and find any complaints. I found nobody really griping about anything but rub with some sizes. My very amateur opinion is that if you drive hard and fast you might notice a slight difference.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
