View Poll Results: When did you replace ball joints?
0 - 50,000 miles 0 0%
50,001 - 100,000 miles 2 7.14%
100,001 - 150,000 miles 2 7.14%
150,001 - 200,000 miles 0 0%
never 24 85.71%
Voters: 28. You may not vote on this poll
Old 03-31-2003, 01:37 PM
Ball Joints
How long did/have yours lasted?
Also which side(s) did you change?
Old 03-31-2003, 01:55 PM
Mr. Pockets's Avatar
Moderator
I haven't replaced the ball joints on my SVX, so I won't vote in your poll. But I will say that at about 150,000 miles my wife's Legacy had a ball joint start showing a little slop. But that was only one ball joint. The other seems fine.
The SVX's ball joints, at 133,000 miles, seems fine.
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 03-31-2003, 01:59 PM
I have one SVX ball joint ready to fall out and it looks like the previous owner changed the other side already (<70,000miles).
The Justy's original ball joints were perfect even after 185,000 miles.
Old 07-28-2004, 04:26 PM
mbtoloczko's Avatar
sans SVX
I just replaced mine at 99,000 miles. Both of the originals had no obvious free play when I removed them. Good insurance I guess.
Mychailo
Visit my locker
Old 07-28-2004, 05:18 PM
Old Fogey
Just replaced both joints at 120K-miles and my mech was told by his parts guy that he "never" sold any of these, and was asked "what happened to screw them up?". I ended up buying replacements from Dave, aka "red95svx", at significant savings I might add! I surmise that someone, changing CV boots/axles, screwed them up. I replaced the swaybar links as well cuz they were showing some obvious age and wear. The ball joints were a MESS, and the very annoying "knock" is gone!!
Glenn
Old 07-29-2004, 06:23 AM
dcarrb dcarrb is offline
No vote from me, either, as I don't know whether or not mine might have been replaced before I got the car, but I will toss-in that after something like half a million miles in 4WD or AWD Subarus, I've yet to replace a suspension or steering linkage component, period.*
I'd be interested in knowing if there's any correlation between SVX ball joint failures and geography; that is, areas that use road salt. (If not the salt, perhaps it's the typically lousy roadways.)
dcb
*EDIT: That is, unless SVX rear wheel bearings count as suspension components.
Old 07-31-2004, 07:58 PM
NapaBavarian's Avatar
Good morning!
If the boots get damaged say bye bye ball joints...
.Karl.
Old 07-31-2004, 08:14 PM
Ralph Gibbs Ralph Gibbs is offline
Ball Joint
Hello David,
I had my lower left ball joint, # 20220pa000 replaced by Mid west
on Regent Sept. 7, 2002 w/ 177,452 km. cost was $191.80
RGG
Bobb Bobb is offline
Ball Joint
Hi everyone, I haven't had too replace ball joints on my SVX but I recently had to replace the tie rod ends. My SVX has just under 100,000 miles on it. I am the second owner of the '92 SVX and have had it since October 1997. It had 31,000 miles on it when I got it. Take care, BOBB
