Old 10-25-2011, 11:38 AM
THE NEW GUY THE NEW GUY is offline
Brake light on when below 12 centigrades.
Does anyone knows what it means when the brake light remains on in the mornig after release the hand brake but turns off after some kilometers? It is not the ABS ligth, it's the brake ligth, the same that indicates low brake fluid level.
I've read somewhere that the ruber on the cap of the brake fluid needs to be bend so it does not interfere witht the floating sensor... Any help please.
Old 10-25-2011, 01:09 PM
Re: Brake light on when below 12 centigrades.
Remove the cap on your brake reservoir. The rubber bladder in your cap will probably look like this:
Collapse the bladder by using your fingers to push it back into the correct position:
The reservoir has a magnetic float in it that operates a reed switch under it, to bring on the E brake light, when the fluid is low. The rubber bellows can hold the float down to bring on the light, just opening the top and folding the bellows back up, will turn the light off.
Replace the cap.
Is your brake fluid level low?
Old 10-26-2011, 07:01 AM
It does a lot of sense. because of teh temp dif. Thanks my friend. The fluid level is OK. I didn't know the right position of the caps's rubber. Now I know.
Old 10-27-2011, 01:51 PM
You was rigth again svxcess. Problem solved. Thanks
