Old 09-16-2011, 07:09 AM
Gamesy's Avatar
Gamesy Gamesy is offline
how to remove paint from taillights
i got a set of rear lights and the guy painted a red candycoat on them, how can i remove the pain without wrecking the plastic?
Old 09-16-2011, 09:30 AM
Re: how to remove paint from taillights
lots of very fine sand paper and clear coat ?
Old 09-16-2011, 07:45 PM
Gamesy's Avatar
i was thinking paint stripper?
Old 09-16-2011, 07:57 PM
NO NO NO!
That stuff will craze the plastic and soften it as well.
I would try and use a medium-cut rubbing compound on a buffing wheel on low speed. Let the abrasive do the work. Don't use too high a speed or too much pressure as that will generate too much heat.
Once it is removed. go over it with a white polishing compound and a plastic polish system like Novus.
http://www.amazon.com/Novus-NOV7100-.../dp/B000J41VDM
Old 09-16-2011, 08:25 PM
Green1995SVX's Avatar
The tail lights are pretty easy to find an inexpensive. I'd think you would be better off getting another set and throwing the ruined ones away.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 09-17-2011, 03:44 AM
michael's Avatar
michael michael is offline
What Potholes ???
Just treat them like yellow headlights. If you've ever cleaned yours. If not, check the how-to's. Green, you must have mad cheese to throw out a good set of tail lights
Wanted: Steering Wheel
Old 09-17-2011, 01:51 PM
Why not? There's tons around and it's not worth the effort IMO of trying to clean them up.
Old 09-17-2011, 07:01 PM
michael's Avatar
What Potholes ???
Said the man with 54 svxs. jk
