Old 08-13-2011, 06:56 PM
davew833 davew833 is offline
What else usually leaks?
So I'm working on fixing some persistent leaks underneath my '94. I've just done the valve cover gaskets, the trans pan gasket, and last winter I did the PS pump o-ring. I suspect it's also leaking a little oil from the separator plate on the back of the engine, but I'm not keen on pulling the engine or tranny to fix that right now. What else is there that commonly leaks on these? (Yeah, I know it's a Subaru-- it's SUPPOSED to leak.)
davew833@yahoo.com
Former 6-time SVX owner
Old 08-13-2011, 07:23 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: What else usually leaks?
Cam & Crank seals. Did you do all of the gaskets on the valve covers including the washer grommets?
Wanted: Steering Wheel
Old 08-13-2011, 09:31 PM
All of the VC gaskets (3 on each side) plus 18 of the 20 grommets. (came up short on 2 of them and re-used old ones with some silicone sealant.)
davew833@yahoo.com
