Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Brake Upgrades
Old 04-22-2009, 08:51 PM
svxash's Avatar
svxash svxash is offline
Drilled rotor direction?
So in the for sale area there was some discussion on which direction the vanes and drilled holes are suppose to go. While at the Chevy/Subaru dealer today I was looking at the Vettes on the floor and took some pics with my phone.
Driver's side
Passenger side
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3
Old 04-22-2009, 08:54 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: Drilled rotor direction?
The drilled holes likely match directional vanes inside the rotors. Those would be correct as "pinwheel" orientation.
Slots are up to much speculation... Manufacturers' advice, designs, and suggested installations will vary (StopTech recommends "buzzsaw", but dba uses "pinwheel"). All told, unless you really really use your brakes, it probably doesn't matter.
Old 04-22-2009, 08:57 PM
Eh. If you've got stock wheels, set them up to match the direction. Looks cool.
Old 04-22-2009, 10:11 PM
svxash's Avatar
I just thought it was odd that each side went in a different direction. I'm assuming that they use the same rotor for both sides. When I installed drilled rotors on our Baja each side had the holes drilled so they were going the same direction.(directional rotors?) Oh and the pics are from a Z06.
1997 Boudreaux LSi
1994 SVX LSi(SOLD)
Old 04-22-2009, 11:28 PM
Talked to stoptech about slot directions and directional and non-directional vanes. The guys at StopTech made this very easy:
Stand facing the PASSENGER side front wheel
Salute the front wheel with your RIGHT hand
Now look at the angle of your hand, your fingers are pointing the direction that the slots should go.
On the DRIVER'S side, do the same thing, only salute with your LEFT hand
Now wasn't that simple??
Old 04-23-2009, 06:02 AM
LetItSnow's Avatar
Yes, and that's grand, but if you read <this post>, you can see that it doesn't apply across the board, whether car by car or brand by brand.
If StopTech advises "pinwheel" for their rotors for the SVX, then that's the way to face them. That doesn't specify direction for any other brand, nor any other car.
Old 04-23-2009, 06:36 AM
The direction of the slotted rotors doesn't matter IF you have standard (non-directional)vanes (straight up and down slots...this can be viewed when looking directly down on the rotor if the rotor were installed). However, if you have directional vanes than placement will matter, and directions from your particular manufacturer would be advised.
Old 04-23-2009, 07:30 AM
Sov13t's Avatar
Sov13t Sov13t is offline
Chris is absolutely correct, the slotted veins within the rotors vary based on application. Our cars have neutral (straight outward) veins, if you were to x-ray our rotor it would look like an elementary school depiction of the sun... straight rays from the center outward. I am referring to the RaceConcept and a few other "cheaper" rotors.
Now, once you get into more race spec stuff, and perhaps modern cars, rotors have more of a "hurricane" like pattern designed to create more flow during movement.
My .02,
-Sov13t
