Old 04-10-2007, 07:08 PM
ahmed-abrar ahmed-abrar is offline
strange sounds from front suspension
recently i have heard 'wooden' knocking sounds from the front offside wheel area, prob a worn bush?
i would like to ask for help in sourceing the right parts & fitting advice, thanks
Old 04-12-2007, 10:32 AM
i forgot to ask, if poly bushes r available as a alternate fit, if so where can they be obtained from?
Old 04-12-2007, 02:36 PM
Ahmed, I'm not really sure what your problem could be, since there are a number of possible noise sources.
However, a worn bush is a very possible cause, although they usually wear out on the near-side first.
Have a look in this thread for ideas:
http://www.subaru-svx.net/forum/showthread.php?t=38047
You can get stiffer bushes for the car, and they will work well. I'm just not sure where you would go locally to buy a set. They are always advertised in the likes of Practical Performance Car or Auto Express, so you should find a local supplier easily enough.
Old 05-17-2007, 01:21 PM
I still have polyurethane bushings for sale if you're still interested. I'm just not sure how much it would cost for shipping.
Old 05-17-2007, 01:35 PM
I would also be interested in a set David. Shipping to Ireland will probably cost around the same as shipping to England.
Let me know the cost incl shipping, I'll take a set.
Old 05-17-2007, 01:43 PM
I'll let you know about shipping either tomorrow or monday.
Old 05-17-2007, 02:20 PM
Thanks David. I'm traveling for the weekend. I'll get back to you Tuesday.
Old 05-21-2007, 01:14 PM
Well I was sick all weekend and today's a holiday so I'll get a shipping quote to you in the next 24 hours or so.
Old 05-22-2007, 07:34 PM
Here are the Canada Post shipping quotes (CAD) from Canada to England or Ireland:
Surface: $18.50
Surface w/Tracking: $35
Air: $45
If the shipping ends up being less I would refund the difference.
Old 05-23-2007, 02:40 AM
Hi David
Thanks for the shipping quote. You did not mention what the cost of the bushings will be. Can you give some information about them? How many in a set? Where do they get fitted? How hard are they to install?
I would be interested, let me know.
Old 05-23-2007, 01:43 PM
Originally Posted by svxistentialist
Hi David
Here's the info:
Front sway bar bushings (pair)
Cost: 30 USD/22.50 Euro/32.50 CAD
Installation: Easy (just don't tighten them down all the way at first)
Rear sway bar bushings (pair)
Installation: Easy
Rear differential bushings (pair)
Cost: 80 USD/60 Euro/88 CAD
Installation: equivalent to replacing a bearing
Old 06-06-2007, 04:31 PM
Sorry for not getting back sooner David. I have been very busy.
I'll PM shortly and probably take a set, maybe two from you.
Cheers man
Old 06-07-2007, 07:52 AM
Is your shipping within Europe as expensive as my shipping to you? If not you should grab a few sets for the European SVXers.
