Old 02-03-2007, 05:16 PM
webdogboo webdogboo is offline
Power steering
I have a problem with my power steering. I have a 97 that does not have the variable assist it should have. As I understand it the car has a two stage assist, low speed and high speed. All I have is the high speed assist which is not adequate for parkiing lot turning. Subaru dealer could not find the problem. The speed sensors are working. I found reference to a PCU unit for the power steering but can not find the location of the unit in the car, anyone know where it is? I had the entire rack assembly replaced with a rebuilt which works fine. Also had the pump replaced at the same time.
Tom - Black 97 88k Colorado
Old 02-03-2007, 09:35 PM
What are the symptoms? Is it just hard to turn the wheel at low speeds or what. It could be the o-ring on the fluid tank.
Old 02-04-2007, 12:13 AM
bcpianoman bcpianoman is offline
Same problem
I'm going to watch this thread very closely because I have the same problem. I just got the car back today from having a 5-speed installed. Everything works great except the power steering problem (which wasn't a problem before the swap) and the seat belt light in the dash won't go off (which was a problem before the swap).
Old 02-04-2007, 12:35 AM
What are your symptoms?
Old 02-04-2007, 01:00 AM
The same as Webdogboo
I have the same symptoms as Webdogboo if I understand his complaint correctly. The power steering does work with no indication of the belt slipping or any other unusual sounds or vibrations. It feels completely normal at high speeds. It's providing some assistance at low speeds but not enough.
I don't think it's the o-ring because there were no problems prior to the 5-speed swap. I'm thinking maybe an electrical connection somewhere.
Any ideas?
Old 02-04-2007, 03:05 AM
Any ideas?
It depends on the system you have.
The vehicle speed sensing system like my JDM has, incorporates an electronically controlled proportional solenoid valve with feedback loop. This is activated via the ECU and therefore an electrical fault could possibly apply.
The engine speed sensing system, which I understand is more common in the US, depends on hydraulic pressure alone, in respect of adjusting power assistance. No direct electrical connections are involved. Operating pressure depends on the engine driven pump speed and an associated flow control valve and varies accordingly.
Old 02-06-2007, 08:54 PM
Any Trauma?
Has your car undergone any trauma (hit curb for example) or had any work done on it that could cause misalignment of the wheels?
Old 02-06-2007, 10:27 PM
do yourself a favor... I just had this same issue that I dealt with today. Check the fuse box under the dash. There is a 10A fuse labeled Cruise/ABS... check this. I have a feeling this may be bad. Replace it with a new one and see what happens... Also check to be sure that the electrical connector it plugged in both at the rack and the PS pump
Old 02-06-2007, 10:29 PM
The US cars mostly had speed sensitive steering but the newer models had RPM sensitive from what I understand... All of them operate off electrical signals
Old 02-06-2007, 10:40 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Could that be the joint needed to be cleaned and greased? Is that called U-joint??
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 02-06-2007, 10:42 PM
when that happens usually rotation is notchy and uneven. These are not the symptoms described
Old 02-06-2007, 10:50 PM
SSSVX's Avatar
that's right, tom. my yellow one seems to be working good at any driving speed but it feels not smooth(light&heavy; not consistent-assited) when the car is stopped.
-SSSVX
Old 02-07-2007, 05:40 AM
dcarrb dcarrb is offline
Did your problem commence when you replaced these parts?
Long shot: My silver SVX had spells of very heavy low-speed PS when I bought the car. The fluid looked like maple syrup. A turkey-baster fluid change, a slug of power steering additive, and 3000 miles later, all is well.
(My understanding is that North American LS models have RPM-sensitive powering steering, while "touring" models have MPH-sensitive assist.)
dcb
Old 02-07-2007, 02:13 PM
dcb
A very worthwhile issues are raised as above.
Could it be that the wrong type of rack was installed. Alternatively if you have MPH assist, that the plug is not correctly fitted, or the wiring damaged./
Old 02-08-2007, 06:21 AM
solarsvx solarsvx is offline
Send a message via AIM to solarsvx
i have the same problem also, i just replaced the belts thinking it was abelt slipping issue,
it only does it at low speeds, it just feels weird,
im going to take a closer looks this weekend check electrical connections andswap the fluid out, but with a car with only30k on it just seems weird
im begning to thik its a bad steering rack or bad ps pump, but works find just whene at low speeds whene its under load its acting weird
2008 evo x with sss package
430 hp 380 torque stock turbo with basic bolt ons
12.56 @ 109 fully weighted 3,500 lbs
