Old 10-11-2006, 08:57 PM
SVX JAZZ's Avatar
SVX JAZZ SVX JAZZ is offline
Tired
Hesitation
An interesting problem has developed... The cold start hesitation now happens even after the car is warm. It also happens when I make a quick turn on to a road - it boggs down. Also when crusing in 4th, part throttle, with the converter in lock-up, it hesitates. When I floor it - all is well.
My thoughts are that it is the MAF. What is the best way to clean it (I have seen several opinions). What about fuel pump?
I wanted to see if anyone had any thoughts before I hand it over to my mechanic.
Paul
Old 10-12-2006, 03:21 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Run SeaFoam through it. If it still does it, (which it probably will.. I've been battling this problem for a year now) my recommendation would be new coil packs. They're about $100 each though, so try to narrow it down to just one of them if you can.
Brian
Old 10-12-2006, 05:13 AM
svx_commuter's Avatar
Have you tried celaning the Throtle Body (TB)? My SVX has done that a few times and TB cleaning has cured it.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 10-12-2006, 06:32 AM
Ricochet's Avatar
I brought some ham.
I take it you've never heard of seafoam, it does this along with cleaning out the fuel system and combustion chambers. Carbon disappears in a big plume of white smoke out the exhaust, 007 style.
Brian
Old 10-12-2006, 07:39 AM
SVX JAZZ's Avatar
Tired
I haven't tried Sea Foam. I have 151,000 on the car so it could use some anyway... I cleaned the TB a while back put a new fuel filter in it and I replaced the injectors a couple of years ago. I had a bad backfire problem that was a combination of leaky injectors and bad coil packs. My mechanic found two packs that were bad and replaced them.
I also wonder if it has something to do with the knock sensors dialing back the timing. I have noticed a little bit of spark knock before. I use the correct gas as well.
Old 10-12-2006, 08:12 AM
n00b on demand's Avatar
Check the TPS voltage
Old 10-12-2006, 09:08 AM
SVX JAZZ's Avatar
Tired
That's interesting... It does mainly happen when the throttle is slighlty depressed.
Old 10-12-2006, 10:49 AM
I'll give that seafoam a try next time. Thanks
Old 10-12-2006, 10:51 AM
I had a hesitation problem in my SVX for a few years. Sold it to SVXfiles and he checked out the TPS and I guess adjusted it to the correct reading and all is well and the torque converter locks up again too. If a coil pack was bad I would imagine there would be a little difference in idling as well. When my coil pack was bad the car idled real rough.
