Old 10-02-2006, 09:21 AM
genzzel genzzel is offline
Will pass gas for $$
4EAT --- will this fit???
Hi All -- I have a 95 SVx that supposedly has 4:11 gearing that was "dealer" done. I changed the tranny oil and filter and found "parts", so I will need to change tranny or rebuild. The question is: Could this be a Legacy trans and rear diff that was installed??? Would a 97 Legacy trans work for replacement??? Thanx for the help. kevin
Old 10-02-2006, 10:04 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Couple of things:
As I've never heard of a dealership-performed 4.11 swap, I'd suggest you do the following:
1. get the number off of the trans and check to make sure it is, in fact, a 4.11 trans
2. check the rear diff to make sure it is, in fact, a 4.11 diff (if it has the SVX's 3.545 tag on it be concerned....)
If a dealership just dropped a 4.11 4HEAT in without changing the rear diff you've got an obvious mismatch of ratios...
What "parts" did you find when you dropped the pan?
-Bill (okay, so maybe my rear diff has the 3.545 tag on it )
Retired NASA Rocket Scientist
Center Network Member #989
Old 10-02-2006, 10:26 AM
i have had the car about 3 months and all is good with the match with front and rear diffs--ie no binding. The trans seems good except for some "flaring" 3rd to 4th. I found what appears to be small rollers out of a thrust bearing--about 1/8th in diameter and 3/16th long. Of interest is the drain plug is on the driver's side--looks like a Legacy trans. Thanks for the input and I look forward to more. kevin
Old 10-02-2006, 10:56 AM
Found a tag on trans and it reads: TZ102ZAAAA-C7 with a serial number of 861xxx Any clue??? kevin
Old 10-04-2006, 05:42 PM
1995 legacy
Old 10-04-2006, 06:56 PM
michael's Avatar
michael michael is offline
What Potholes ???
By any chance it your car claret?
Old 10-05-2006, 02:51 PM
Green 1995 SVX from Pittsburgh area/ Meadville area
