Old 06-18-2006, 09:10 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Rims on E-bay
Has anyone bought rims on E-bay for their SVX? Are they any good?
Old 06-18-2006, 11:47 AM
shotgunslade's Avatar
If you're looking for a set of stock rims. I have a set for sale. Mounted with 225/50-16 Pirelli P Zero Nero MS's (great tire) with maybe 75% of tread left. Also have an unmounted Pirelli P Zero with maybe 50% of tread left. PM me if you are interested.
Old 06-19-2006, 11:29 AM
I've bought a couple sets of rims from eBay. They all arrived in the stated condition.
Old 06-19-2006, 03:10 PM
Suby Fan's Avatar
Suby Fan Suby Fan is offline
it depends on if you trust the seller check their feedback... but yea they are fine
- John
