Old 02-24-2006, 10:44 PM
drivfour drivfour is offline
no interior lights
I do not have elect. diagram yet. Chiltons from library did not have in book. The problem is that the map, cabin nor lights on door will come on. I checked both fuse boxes. Can someone let me know circuit(s) these are on or send pdf of schematic. Also, How does door signal open? Do not find the normal push button on door frame.
Thanks
JD
92 svx ls-l
Old 02-24-2006, 11:36 PM
Did you accidentally press the ROOM or DOOR buttons in the light console in the roof? I believe the ROOM button can turn off the lights in the doors and cabin until either the ROOM button is pressed again or the DOOR button is pressed.
The 92 Owner's Manual (page 5-20) says:
To use the interior light regardless of whether the doors are open or closed, press "ROOM"
To use it while the door is open, or to turn it off when the doors are closed, press "DOOR"
Old 02-25-2006, 03:09 PM
lights
no combination room,door spots has them on. clock also not on. Lights on end of door also not working. Visor light works however.
JD
