Old 02-03-2006, 07:45 PM
NFSvxSpeed
Lightbulb Is a 1996 legacy 2.2L plug and play for SVX Swap???
can it be done, will it work good, what ratio is it. ( transmission )
its a 2.2L.
thanks.
Old 02-03-2006, 07:47 PM
DarknessofDeath's Avatar
Inhabitant of Darkness
yeah...isn't that the 4.11 or the 4.44
i'im actually not sure at all...but i think i read about the legacy 9.6
but you needed it to have rear LSD since you would have to swap that too.
Old 02-03-2006, 07:52 PM
NFSvxSpeed
i dunno.
Old 02-03-2006, 08:27 PM
Tranny would be a plug and play, but you'd need to swap a matching ring and pinion for the rear diff to complete the swap....
Old 02-03-2006, 08:31 PM
NFSvxSpeed
Lightbulb
Can i just replace the rear diff from the tranny donating car?
What the final ratio on it 4.44?
Old 02-04-2006, 01:48 AM
4.44:1 is the final drive ratio. No you cannot just swap over the new diff unless you really feel like losing your LSD abilities
Old 02-04-2006, 05:36 AM
If it is a 96 Legacy, not an Outback, the final drive is probably 4.11.
And the SVX axles won't fit into a Legacy open rear diff, so you'll have to swap the ring and pinion to complete the swap.
Old 02-04-2006, 08:40 AM
Thats right. Because the SVX rear axles has one that portrudes longer than the other it would hang up on the spider gear spider gear shaft... Never thought of that.
