Old 03-02-2006, 02:17 PM
You don't need anything. Take a look at your stock exhaust...that will answer your question for you.
mbtoloczko's Avatar
sans SVX
That's the correct format for the connection between the muffler and the center pipe. There is a special band-clamp and donut gasket that holds the pieces together. The OEM band clamp and donut gasket should be reusable.
Mychailo
Visit my locker
Old 03-02-2006, 02:19 PM
wynndi's Avatar
wynndi wynndi is offline
Send a message via AIM to wynndi Send a message via Yahoo to wynndi
Resonator looks like a high quality "Glasspack" take a look inside:
Dave W.
______________________________
1996 Redd
gest24's Avatar
$ gest24 $ gest24 is offline
#1 6MT In Cali
Big DUH moment on my part. I think it's off to go install the Stebro.
Sand Diego SCCA Solo 2 #308
RIP
84 VW Scirocco
02 WRX
Check My New Homepage..
Old 03-02-2006, 06:45 PM
gest24's Avatar
#1 6MT In Cali
YAY! Installed... needed to buy some harware and re-tap and dye my "C" clamp. But all in all went well. Also put some royal purple in the diffs and engine.
RIP
84 VW Scirocco
02 WRX
Old 03-02-2006, 10:02 PM
Dza's Avatar
Dza Dza is offline
#073 of 301
Were you kinda disappointed when it wasn't as loud as you thought it would be? From the opinions on here, I expected it to be "Armageddon is upon us" loud, but it was just kinda... $900 worth of farty. ?
Dan M.
Barcelona Red '93 AE #073 of 301, 168k miles.
Old 03-02-2006, 10:18 PM
gest24's Avatar
#1 6MT In Cali
I like the sound. It brings out a decent note without sounding gay like a V8 domestic or gay like a CRX with a coffee can. (Don't mean to offend anyone with my word choice)
RIP
84 VW Scirocco
02 WRX
Old 03-03-2006, 07:16 AM
The sound is deeper without the center cat. Mine's about as loud as I'd ever want it to be.
Old 03-03-2006, 09:56 AM
wynndi's Avatar
One time, at band clamp......
....couldn't resist!
It sounds as if most of the installation hardware is reusable, that's good news. My '96 gets the install tonight or tomorrow.
Dave W.
1996 Redd
Old 03-03-2006, 05:21 PM
gest24's Avatar
#1 6MT In Cali
Penetrating Oil is a must!!! I sheered off the bolts from the center pipe to cat. Also you might want to get a bolt and nut to use on the "Bolt on" muffler hanger.
RIP
84 VW Scirocco
02 WRX
Old 03-03-2006, 07:27 PM
Dza's Avatar
Dza Dza is offline
#073 of 301
Did you remove that center cat? I liked the note your exhaust had, but mine does not sounds like that.
Dan M.
Old 03-03-2006, 07:54 PM
wynndi's Avatar
If you do remove the center cat, in a Stebro setup, what do you replace it with?
Dave W.
1996 Redd
Old 03-03-2006, 08:13 PM
AFBeefcake's Avatar
Subaru Swapper
The Stebro Euro Resonator, but I don't think it would work with a odb2 svx.
2005 Legacy GT
My WRX's Cardomain Page
Old 03-03-2006, 08:17 PM
gest24's Avatar
#1 6MT In Cali
Which is another $425
RIP
84 VW Scirocco
02 WRX
Old 03-06-2006, 10:19 AM
I didn't remove it. I just beat the stuffing out of it.
