Old 12-20-2005, 11:00 PM
dwd1985 dwd1985 is offline
Boxer engines
Can someone tell me what cars subaru has made with a boxer engine besides just our beloved SVX'x and the new B9 Tribeca? My father told me they were also put into the WRX's and Outbacks, but I just dont know...
Old 12-20-2005, 11:10 PM
Weebitob Weebitob is offline
The Kind of Casual SVXer
Send a message via AIM to Weebitob
Subaru has been using boxer engines since the 1965 Subaru 1000, their first car the 360 used an 4 cyclinder incline engine. Since then Subaru used the boxer configuration on a majority of their engines. In other words almost every one of Subaru's cars uses a variation of the boxer engine from the Impreza to the Tribeca. The only cars not to have this type of engine and use an I4 instead is the 360, R2, Vivio, Pleo and modern R2. Every other Subaru uses the boxer engine.
If you want to know the difference between the boxer engine and other types of configurations just look at this annimated gif. The main reason for it being called a "boxer" is because the cylinders configuration make the entire engine or at least the block shaped like a box.
Other here probably have vastly more information and can explain more of the technical aspects better.
Old 12-20-2005, 11:28 PM
pavanbabut's Avatar
I dont know abt the very old models, but all of the Subaru line-up now comes with boxer engines. You can get the whole history of Subaru at Subaru-Global. Hope this helps you understand about Subaru in more detail.
-Pavan
Old 12-21-2005, 12:09 AM
SlonSVX5mt
since like 1985 subby been makin boxers
in all cars
Old 12-21-2005, 05:33 AM
dcarrb dcarrb is offline
I'll never forget the first time I popped the hood on what would become my '86 GL wagon and saw that gutsy little boxer four with the spare tire atop the gearbox. What a surprise to see a north/south powertrain configuration, the way God intended. I'd had no idea.
dcb
Old 12-21-2005, 05:54 AM
n00b on demand's Avatar
Boxer engines are in every subaru.
Old 12-21-2005, 09:37 AM
red95svx
Yes, but only if you mean current Subarus. The Justy (87-94) had an in line 3 cylinder.
Old 12-21-2005, 09:52 AM
red95svx
A Boxer style engine is an engine with a horizontal layout. The pistons moving toward each other from opposite sides resembles two "boxers" punching at each other, and hence the name Boxer engine. Currently Subaru uses this configuration in every U.S. vehicle.
What your father may be referring to is Subaru's six cylinder boxer engine, which has only been used in four U.S. models: the XT6 (2.7L), the SVX (3.3L), the Legacy Outback (3.0) and the Tribeca (3.0L).
Old 12-21-2005, 10:47 PM
maybe it's called a boxer because if you look at the motion of the piston it looks like two arms on each side trying to punch the head?? I dunno but its a thought
Old 12-21-2005, 11:03 PM
If i remember correctly that is why they are called boxer engines
Old 12-21-2005, 11:22 PM
I always thought it was named after the dog.
Old 12-22-2005, 09:11 PM
It's Just Eric's Avatar
Missing in action
Mabey its called a boxer engine because the engines inventor used to be an elf that packaged presents for santa clause in his special UPS warehouse up in canada.He named it out of bitter anguish over his previous employer, making him do a years work in a month, and it permantly had boxes in his dreams..All he could think about was boxes and horizontially opposed engines. HE was a weird elf..... But then again I might be a little off.
R.I.P Cool Signature.
Old 12-22-2005, 11:28 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
Bingo!! My money is on this one.
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 12-23-2005, 06:30 AM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
"A flat engine or boxer engine or horizontally opposed engine is a type of engine where the pistons lie horizontally opposed, with pairs of cylinders on the left and the right, as opposed to most modern engines where all pistons are inline, or the alternating pistons are positioned in a "V"-angle.
Experts distinguish between V-at-180° engines and real boxer engines (horizontally opposed engines). The horizontally opposed engine has one crank pin per piston while in the V-at-180° engine two pistons share the same crank pin.
The benefit of using an horizontally opposed engine engine versus a V engine is that it provides perfect balance because each piston's movement is exactly counterbalanced by the corresponding piston movement of the opposite side. These engines can run perfectly smooth and free of vibrations with a four-stroke cycle, regardless of number of cylinders, and do not require the counterweights on the crankshaft to balance the weight of the reciprocating parts which are required in other engine configurations.
Automobiles and motorcycles powered by a flat engine generally have a lower center of gravity, giving better stability and control. However, these engines are also wider than normal engines and are more expensive to build than traditional engines and, thus, are not widely used by automobile manufacturers."......answers.com
Gene and Ben
Old 12-23-2005, 09:28 AM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Not all current Subarus have boxers either. Remember Subaru/Robin makes V-twins, OHV and OHC single cylinder engines. I don't think the current Sambar has a boxer either. Isn't it a 660cc V twin?
