Removing the rear bumper cover... how?
I was rear ended (slightly) and I didn't see any damage, so I didn't take the guys information. However, now that i look at it, I notice there's a pretty big gap between the 1/4 panels and the bumper.... I'm guessing hte cover just shifted a little. How do I remove the cover, so I can reinstall and tighten up that gap?
I never removed mine when I was rearended. I did have it repainted but spider cracks can still be seen in the bumper even after the repaint. I really hate spider cracks!
Like this:
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=14 This is what's happened to my SVX. Anyone have an exploded view of how the bumper is attached? |
Looks like you can't remove just the skin until the bumper is removed. Instructions state. 1) Lift the car and pull down the rear of the inner fender/liner and remove bolt each side from side of bumper. 2) Remove bracket (side LWR) from car body 3) Remove trim panel (trunk rear) and detach rear side of trunk trim (sides) 4) Remove rear wiper washer tank (right side only) 5) Remove nut from side of bumper (difficult to determine even with FSM diagram but appears to be under and to outside of spare tire well ) 6) Detach cap and remove bolts from bumper stays (in trunk floor) 7) Pull out bumper side mounting bolt from body (behind wheel well) 8) Slightly lift loose rear bumper to disengage hook from body, and take out bumper.
Hope that's some help? Glenn
"The only thing necessary for the triumph of evil is for good men to do nothing" Aaron Burke 1993 25th Anniversary Edition #63 of 301. R.I.P. Rojo 7/24/2008 She saved my life! 1997 Ebony Mica Pearl LSI. BLACKBERRY 1998 5-Spd Legacy GT Wagon in Glacier White: NUBURU 2005 Cadillac STS in Sandstorm Metallic: STORMY Veteran and farthest traveler of 1st SoCal2MuseumsMeet2010. http://www.subaru-svx.net/photos/user.php?RojoRocket |
Yeah, actually. That must mean that the bolts are inside the trunk. Thanks! I'm going to try to just loosen all of them, have someone lift on the bumper, and tighten them down to eliminate the gap (hopefully)!
if you pop open the trunk, lift up the carpet
youll see to big rubber plugs on either side Pop off the plugs and youll see 2 I believe 13/16s or like 18mm bolt heads. Theres no adjustment there since the bolts go screw down into the frame. If you remove all 4 bolts, and a few 10mm nuts in both sides of the inner rear wheelwell from inside the car, you can remove your bumper. I havent found a good way to adjust it up though. If it was hit hard enough, you may have to take it to a frame shop for a few hours on the frame rack.
My mom will forever live in me and never be forgotten, one day Ill see her again CLICK the LINK below to Visit the SVX Store: http://www.planetsvx.com http://www.motorsportwarehouse.com/svx/sig2.jpg Cars in the garage: 92 Toyota Soarer Single Turbo JDM RHD 70 Boss 302 Mustang 39k original miles 97 SVX Lsi 92 Liquid Silver Murano-ized (1st of its kind) 71 Cougar Xr7 Conv 351c 4v 4spd 69 SS Camaro 350 71 Nissan RHD Fairlady Z 70 Stang Fastback 70 Amc AMX 390 71 240z 89 Conquest TSi w/ 5.0 v8 swap 84 Mustang GT Turbo conv "good, if it bleeds, we can kill it ....." |
After getting the cover off you can put a jack under the bumper itself to adjust it upwards (worked on my Integra)
Re: Removing the rear bumper cover... how?
I took my bumper off today to build an integrated hitch. It was pretty easy getting off. For those of you trying this I think you will find your bumper will need some kind of straightening from being hit since there is a big piece of styrofoam in it and it ain't too structural like that! To help further I would think those little hooks they hang the bumper on to mount it might be bent slightly, or even off their hooks, making it impossible to get alignment. If anyone has trouble indentifying position of the bolts for removal, let me know and I will clarify.
