Old 05-01-2004, 01:19 PM
svxsubaru1's Avatar
Whats the diameter of the exhust system stock, when it comes off the headers?
I need to do some work on it, and was wondering whats the diameter of the exhust system stock, when it comes off the headers? I know this should be in the mod fourm but isent 2.5 inch when the pipes merge a good size to go for when you make one up, for alillte more performance?
Old 05-01-2004, 10:25 PM
svxsubaru1's Avatar
I know some one has to know this. I went through and searched but could only find that it is around 1.5 inches.
Old 05-02-2004, 01:42 PM
Not sure but isnt an Inch increase pretty substantial for just a stock car ? Or is yours modified? Just curious as well b/c since the 5spd swap my exhaust is sitting right on my crossmember and it vibrates and sounds like a riced out civic...:*( Not good.So i too need to know the correct size for best performance all around as well.
Old 05-02-2004, 08:10 PM
wawazat??'s Avatar
Yeah, I'm still around
Check this thread
http://www.subaru-svx.net/forum/show...hlight=exhaust
and remember the Search button above is your friend
Todd
Down to none
Old 05-03-2004, 01:54 PM
mbtoloczko's Avatar
sans SVX
Here's what's not posted in the other thread:
From the manifold to the primary cats, the ID is about 43 mm.
From the primary cats to the secondary cat, the ID is about 38 mm.
Mychailo
Visit my locker
Old 05-03-2004, 04:54 PM
svxsubaru1's Avatar
Thanks, i tried a quick search but couldnet find any thing certain.
Old 05-03-2004, 09:01 PM
tancred
Going to get some headers made eventually with 2" from the headers back....
