Old 06-13-2003, 05:48 PM
Chicane Chicane is offline
Anti-BS Vigilante
Where does my PS fluid go???
About every 3-4 weeks I have to pour in more Dexron 3 to fill it back up. I know where my oil is going (through the leaky seals), but what could be leaking on the PS system? I've replaced a few high pressure hoses on my past cars, but that's because they were over 20 yrs old. Anyone have any ideas on how to track it down?
- Rob
Old 06-13-2003, 08:26 PM
svx_commuter's Avatar
Hi
I haven't had this problem yet.
I remember from reading other threads it's going into the rack boots.
They recommend Lucas PS additive to stop the leak. Add it before it's too late.
SuperbVehicleXtraordinary
Proud sponsor of a 1992 SVX.
Old 06-13-2003, 08:30 PM
immortal_suby's Avatar
Thread Killah
I've had to replace PS return lines on both cars. They leak slow for a while but I never really saw any drips under the car.
Locker Link
2015 BRZ Limited 6MT
Old 06-14-2003, 09:07 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Possibilities:
O-ring in pump
hoses (high and low pressure) from pump to rack
rack itself
I had to replace my rack because it was leaking so bad. Went ahead and replaced the high and low pressure lines at the same time.
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 06-16-2003, 02:45 PM
Anti-BS Vigilante
I replaced the O ring when I got my car. How would I tell if its the rack, or the hoses?
- Rob
Old 06-16-2003, 03:30 PM
SVXRide's Avatar
Get your car up on a lift, spray everything off (Simple Green, Brake Cleaner, etc. -- make sure everything has cooled down first), wipe it down, then run the car and see where the fluid is coming out.
Old 06-16-2003, 04:32 PM
Thread Killah
turn the wheel lock to lock when you do this to send some pressure through the system if you don't see any leaks right away
Locker Link
Old 06-16-2003, 04:39 PM
Porter
I'm drooling over an STi short ratio steering rack. I want one in my SVX badly. I'm sure it could be modified to fit.
Old 06-16-2003, 09:50 PM
dEaD
I had the same problem b4 then one day I wake up to go to work and I couldnt pull out to the driveway
anyway you should check the 2 hoses behind the engin they are bend too hard and thats what caused it to leak you should replace them also I bend the pipe comming out of the penion to the back to make the angle 90 degree between the 2 ends and since then no problem at all
