Old 08-08-2012, 12:57 AM
gjhumphris's Avatar
gjhumphris gjhumphris is offline
Wheel Sizes
OK, next topic ........... wheel sizes.
As the SVX is new to me, I need to ask about experiences with changing to a different wheel style / size. I have read a couple of bits and pieces on the forums that people have changed wheel sizes, then had to alter suspension, etc to fit in larger wheels. At present, my SVX has the original wheels and I'd like to change to a 17" or 18" wheel and have them protrude out a bit further (offset?) without any suspension / brake changes. I'm not sure if I fully understand offset, etc, but is it fair to say that the original is "55" offset and the smaller the offset, the further they protrude? Also, is the stud pattern 114.3?
I'd just like to give the car a little more of an agressive look, without being silly. The originals look a little too small and too far inside the body. Ideally I'd love to put on something similar to this ......
http://www.carpoint.com.au/all-cars/private/details.aspx?Cr=1&R=12970417&keywords=&trecs=8&__s id=12DC3AE052DA&__Ns=pCar_PriceSort_Decimal|0||pCa r_RankSort_Int32|1||pCar_Make_String|0||pCar_Model _String|0&__Qpb=1&__Nne=15&SearchAction=N&seot=1&_ _N=834 1216 1246 1247 1252 1282 4294967060 4294729572 4294967079 4294739619&silo=1011
Any thoughts as to what to look for and not look for in terms of size, offset, stud pattern, etc would be much appreciated.
Cheers,
Grant
Old 08-08-2012, 06:59 AM
'E''s Avatar
'E' 'E' is offline
Re: Wheel Sizes
i'm running this combo on mine 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear (same offset as 350z) which fills the arches nicely, the only thing i needed to do was add some camber bolts to the rear and your tyres don't need to be as wide. if you don't want to add camber bolts then stay with 35-42 and 8-8.5x18s
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 08-08-2012, 07:05 AM
'E''s Avatar
'E' 'E' is offline
Re: Wheel Sizes
this is a 18x9.5 with +20 offset
http://www.subaru-svx.net/forum/atta...7&d=1342073545
http://www.subaru-svx.net/forum/atta...5&d=1342073456
93 black SVX
95 bright red SVX
Old 08-09-2012, 12:30 AM
flamestone's Avatar
flamestone flamestone is offline
Re: Wheel Sizes
For me, standard 18s from a current model Tribeca are perfect with the factory centre caps with Subaru logo.
All you need then is 225/45 tyres to have everything rolling nicely. Which I'm guessing is not what the person before me did when fitting the wheels originally... the existing wheel arch damage looks suspiciously like someone tried to drive with over-sized tyres on it. Doh!
Old 08-09-2012, 04:55 AM
gjhumphris's Avatar
Re: Wheel Sizes
Thanks, mate, for all the info' - that really helps!
Love the pearl white SVX! Beautiful! The Tribeca wheels suit it well.
Old 11-26-2012, 04:35 AM
gjhumphris's Avatar
Re: Wheel Sizes
Can I please confirm that the following wheels / tyres WILL fit the SVX without the need for camber bolts or any other issues please:
18" x 8" rims with 245/40/R18 tyres and offset 45+
OR
17" x 8" rims with 225/45/R17 tyres and offset 35+
Need a quick reply as they're on ebay!
Thank you!
Old 11-26-2012, 06:14 AM
Re: Wheel Sizes
My summer Tyler's are running on 18" rims by 8" wide and using 225 x 40 and a 45+ offset with a 5/114 bolt pattern.
My winter tires are 215 x45 tyre 17 x7.5 rim 45 offset
I think the 35 offset with that wide of a tyre is going to rub, it will be close
Try using this it helped me
http://www.1010tires.com/tiresizecalculator.asp
Old 11-26-2012, 12:42 PM
WYOSVX's Avatar
WYOSVX WYOSVX is offline
Re: Wheel Sizes
You might consider looking at some of the other posts regarding wheel size, especially with regards to concerns over handling and potential rear bearing wear with more of a "protruding" offset. The look you're going for looks great on the SVXs I've seen in the pics, that's for sure.
Old 12-01-2012, 12:22 AM
gjhumphris's Avatar
Re: Wheel Sizes
I have put this on another thread, but also just want to ask the Aussie SVX enthusiasts:
Saw a nice set of wheels on ebay. The new wheel size would be 17" x 7.5"; 5 x 114.3; 225/45/R17 tyres; BUT +38 offset.
According to wheel offset calculators, this means the wheels will sit 17mm further from the calipers and 17mm towards the outside guards. Will this fit WITHOUT rolling in guards / using camber bolts? Would this be too much stress on the bearings?
Thanks!
