Re: Rotor Replacement
make sure your e-brake is off when taking off the rear rotors.
Mike 1992 SVX LS-L Pearl White 102,000 miles (Gone) 2005 Evolution 8 SSL Tarmac Black (new daily) 1995 Eclipse GSX Durango Copper Pearl (teh beast) 276awhp/280awtq @ 18psi (560's inj) 260awhp/260awtq @ 17psi (stock inj) |
I was referring to the improbability that after 150,000 miles or so our rotors might only be a little glazed.
Now that prospective is funny... benebob, if you desperately need someone to argue with, I am sure you could get someone closer to home... wife, ex-wife, etc |
If you DO buy new rotors..... do NOT get the cheap ones which are made of Chinese steel and will warp much more easily then American steel due to the metal quality. Make sure you get American steel rotors..... if you want you can hold the two side by side and compare the weight...... the American steel will be quite heavier due to the higher steel density. I say this because I installed them for 3 years and the cheapies almost ALWAYS came back within a year warped..... and we had to turn them under our warranty.
[QUOTE=SoCal LS-L;604299]If you DO buy new rotors..... do NOT get the cheap ones which are made of Chinese steel and will warp much more easily then American steel due to the metal quality. Make sure you get American steel rotors....
A couple of years back I bought the front rotors and it said right on the 2 boxes "Made in USA! I was elated till I discovered that the boxes were the only thing that was actually "made in the USA Keith |
Replacing rotors (and rear wheel bearings) today with a set from Motorsports Warehouse. Not sure where they are made but are thicker than stock.
Gene
how much are they from ms??? I need new rear rotors and front right wheel bearing
HTML Code:
how much are they from ms??? Rears $145.00 drilled only. Shipping $45.00 to FL and they came fast. Gene
Yeah the cryos are awesome, very resistant to warping since the deep freeze aligns the metal lattice, making it very consistent all the way through. Usually a little pricey though... how much did yours set you back?
Thank you for your patronage, it seems the ART Product has served you well for many years. The cost of the ART Front & Rear Brake Kit on your 1992 Subaru SVX 4WD would run you $514.00 plus shipping & handling to your zip code. The ART Brake Kit consists of gas-port slotted, cryogenically treated brake rotors along with a set of Posi-Quiet Extended Wear Semi-Metallic Brake Pads. We can provide you with the O.E.M. Posi-Quiet Unloaded Front Calipers (rebate available upon return of original caliper cores) for $100.00 If you decide to order the entire Front & Rear ART brake Kits with Front Calipers, you would receive a 10 % discount. Please keep in mind that each ART Brake Kit is custom engineered, manufactured, & cryotreated in-house and your order may involve a lead time. ART Brake & Suspension Systems may be purchased by order over the phone at (714) 527-9400. Thanks for your inquiry. Padmanabhan (Pad) Nilakantan Applied Rotor Technology www.appliedrotortechnology.com Office / Fax: (714) 527-9400 |
