double up the flexplate
since so many people are having issues with flexplates since they keep breaking couldn't you just double up 2 flexplates since they are so thin. then for spacing due to the TC and bellhousing just put a shim there? and voila! thicker plate
Re: double up the flexplate
Tom |
i wish i knew that existed b4 i picked up my oem from subaru, where do you get one of those from?
I've always figured flexplate cracking to be a maybe-once-in-the-life-of-the-car failure. Is it a recurring problem that warrants preventive measures?
dcb |
SVXride had a string of bad luck with those... I think he lost at least 2 in the same car. Any 4eat 99+ should work Tom |
any 4eat 99+ flexplates or trannys? i thought only 98 and earlier only worked on the car
Exactly, which is why you want a 99+ flexplate from one of the trannies that doesn't work (easily) with the SVX.
