Old 02-08-2006, 01:48 PM
Earthworm's Avatar
Meow!
Is anyone currently having trouble accessing the SVXipedia on http://svx-iw.com ?
I've had one person report an issue and I'm trying to track this.
The server has a dynamic IP address but seldom updates. When it does your computer may cache the old address. For Windows XP you can clear this cache by running the command "ipconfig /flushdns". If that doesn't help you will need to wait for your DNS server(s) to update.
Old 02-08-2006, 05:06 PM
Yes, mine doesn't work most of the time. But I go to the How-To at the SVX Forum most of the time.
Old 02-08-2006, 07:57 PM
Budfreak's Avatar
Budfreak Budfreak is offline
Banned
Send a message via AIM to Budfreak
How long before we are able to view the registered owners or at least get a number up of registered owners? Just wonderin
Old 02-08-2006, 09:57 PM
Yes, when David?
Old 02-09-2006, 10:13 AM
Earthworm's Avatar
Meow!
Well Earl can already see them all (because he's special). I'll start working on a query page where you can search by VIN.
Old 02-09-2006, 11:44 AM
Earthworm's Avatar
Meow!
I believe I found the problem. All should be fine now. Just waiting for some confirmations from a few members.
Old 02-09-2006, 01:02 PM
Budfreak's Avatar
Banned
Working just fine for me.
Old 04-28-2006, 12:22 PM
Earthworm's Avatar
Meow!
The SVXipedia will be down shortly some time tomorrow.
It's currently running off my home DSL connection. I have TV service coming through the same line which I'm cancelling. The one box that serves my TV and Internet will need to be returned in favour of a regular DSL only modem.
Outage will hopefully be less than an hour.
Old 08-18-2006, 06:21 PM
Earthworm's Avatar
Meow!
Wow, haven't posted here in a while.
I've been riddled with many disconnects in the past little while and finally decided to look into the issue.
I figured the problem was going to be one of 3 things:
1. the router
2. the ISP
3. flaky power
1. For several years I've been using a D-link 624 wireless router. To eliminate this as the cause of this issue I put together a computer with 2 NIC's and Winroute. http://svx-iw.com/ is using that computer as a router now and everything seems much more stable.
I looked into people having trouble with D-link routers and it seems they can't handle the pressure of many multiple connections and reboot as a result.
I ask, to those with router experience, what you would recommend as a replacement router. It's not going to be D-Link for sure. I would continue to use the computer as a router except I only have one UPS and it's not big enough to handle 2 computers. It's big enough for the web server, network switch, DSL modem and router though.
After doing a tiny bit of research I'm curious about trying an Airlink AR504 router. It seems to be quick and inexpensive. I don't need wireless.
Old 12-22-2006, 11:14 AM
Earthworm's Avatar
Meow!
Been a while since I've updated this thread. I've been borrowing a Linksys WRT54GS 2.0 for a while and was working great. I recently bought a WRT54GL 1.1 and have been using that for about a week now.
Right now the SVXipedia and all of http://svx-iw.com are down due to ISP issues. I have an issue with the DSL modem freezing up. Problem started Dec 4 and I was supposed to get a tech to look at the issue last night. The tech was a no-show.
I apologise to everyone for the outage but will be working on resolving the problem as soon as possible.
Old 12-22-2006, 02:41 PM
Ah, that explains things.
But for such a great pool of easy access information I don't think any member here would complain about a little technical difficulty downtime.
Old 12-22-2006, 02:45 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
It will be well worth the wait. Thanks David.
Gene
Gene and Ben
Old 01-03-2007, 06:48 AM
Earthworm's Avatar
Meow!
Ok, I had a tech show up and determined I was connected to a bad port in the junction box outside my house (their issue).
I've been back up 100% since then and DNS issues fixed themselves.
Svx-iw.com should now be accessible by all once again. I would be very interested in hearing from anyone who sill cannot access the SVXipedia.
