Old 10-05-2006, 09:50 AM
Originally Posted by dcarrb
Elementary question: Have you tried holding the gas pedal to the floor while cranking? I nearly drained the battery the first time mine didn't want to start, 'til I matted the gas. Fired-up immediately. No CEL, and I didn't check for codes. Only gave trouble around 32 degrees with a cold engine, and I haven't had a problem since replacing the ECU temp sensor.
As to the gas smell, check the hoses and connections around the fuel filter. I had a line seeping fuel under pressure even though the clamp seemed tight.
Good luck.
dcb
I only pumped it on one occassion.
I'll try that now.
Old 10-05-2006, 02:59 PM
I didn't try it after I posted but I just got home, tinkered a bit, turned the starter and floored the gas and she started right up with a lion's roar.
Thanks for all the help.
Old 10-05-2006, 05:06 PM
is it doing this all the time?? If so, you may just have a bad temp sensor
Old 10-05-2006, 06:43 PM
First/only time this has ever happened.
And with the new battery all my starting troubles with the clicking and turning the key back and forth are gone.
It's running like a top.
Old 10-05-2006, 06:45 PM
glad to hear it
Old 10-05-2006, 07:08 PM
oab_au oab_au is offline
Originally Posted by NikFu S.
Whoops.
Went out and bought a battery because my mom wouldn't shut up about it and she was sooo confident that was the problem.
Not to humor the woman.
Nick you are old enought to know that your Mom is allways right.
One Arm Bloke.
Tell it like it is!
Old 10-05-2006, 08:29 PM
Well, I am smart enough not to rub it in her face when she isn't.
I waited until she asked me if it fixed it, I said no and left it at that.
Old 10-05-2006, 11:33 PM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
Glad to see your SVX's been started by such an easy way...yeah your old optima battery was a junk
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 10-06-2006, 12:37 PM
Earthworm's Avatar
Meow!
I'm thinking the rough start is a leaky injector allowing fuel into the cylinder while the engine is off.
Old 10-06-2006, 05:54 PM
It's not doing that anymore because I have major cranking amps, but I was thinking earlier maybe it wouldn't start because it was just flooded.
Possible, neh?
