Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #436
Old 10-06-2007, 11:24 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Do i smell photoshoot coming soon?
How's it running?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-06-2007, 03:07 PM
Originally Posted by SVXRide View Post
Nice! Any initial impressions?
-Bill
runs smooth... other than that, there is nothing more to tell. Tim, no photo shoot until I can get her all cleaned up. she got dirty in the shop for 2 weeks
Old 10-07-2007, 11:45 AM
think I found my vacc. leak. I never resealed the IAC to the adaptor.... sealed the adaptor to the TB but not the IAC... Waiting a lil while for the sealant to make up and then I'll start it again
Old 10-07-2007, 12:22 PM
sicksubie's Avatar
and I found my power steering leak.... YT is dropping a new hard line in the mail for me. Once I get that I can tighten everything down, install the new software, hit the track, and then hit the dyno again.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-07-2007, 01:58 PM
well... my issues are not ironed out either. I re-sealed the IAC but with no real luck. It will idle nice w/ a good AFR for about 3 seconds then the idle drops down and it'll run super lean (off the map). I am going to replace the IAC when I get back to philly and hope for the best.... These are the same issues I was having with the idle before the motor build so don't go thinking thats the issue
Old 10-09-2007, 01:46 PM
cdigerlando cdigerlando is offline
Do you think it could be the auxiliary air unit? I just had to replace an IAC in my WRX. They are expensive.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 10-09-2007, 01:50 PM
i am going to replace it hopefully tomorrow... I will let everyone know
Old 10-12-2007, 12:11 AM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
you get it replaced yet?
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
Old 10-12-2007, 04:45 AM
no not yet
Old 10-15-2007, 08:33 PM
Main Bolt Torque
Tom:
How much torque are you using for the main bolts? I have some documentation that says 20 ft-lbs and other documentation that says 29-35 ft-lbs.
Thanks
Chuck D.
Chuck D.
Old 10-15-2007, 08:49 PM
the main bolts are a sequence. 11ft-lbs to start then a sequence of tightening them by angles. You should pick up an angle bit for your torque wrench. Thiswill help you precisely measure you stretch torque angles.
Old 10-15-2007, 09:00 PM
longassname's Avatar
Just some dude.
ya you need to follow that factory torque sequence......
I've noticed when caging bearings that the main oil clearances don't even come out right if you don't use the factory torque sequence.
Old 10-15-2007, 09:05 PM
same reason my oil clearnances on the rods were all wrong with overtorqueing them too.
Old 10-16-2007, 12:00 PM
Torque
I see. 20 ft-lbs is for the other case bolts not the bearing bolts. The bearing bolts go 11 ft-lbs then 90 degrees more. The manual shows the sequence too.
Thanks
Chuck D.
Old 10-16-2007, 12:03 PM
no... I think you are seeing 20* as 20ft lbs
