Bosch Platinum 4+ Spark Plugs
I bought these recently and haven't put them in my SVX yet but was wondering if anyone has had experiance with these and should I keep them or fork out $2 for the NGK? Please don't post "they are crap because I think they are" I'd like a little info not just straight opinion Thank you~
*EDIT* I said screw it and went back and got the NGK after looking around some more. they are the NGK Iridium IX Spark Plugs, $8 a peice lets see how they par up against the Autolite or what ever that is in there now.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles Last edited by Wikedjuggalo; 05-10-2008 at 05:17 PM. |
I read not to attempt to regap these? That being so should i be worried about the Gap with the svx?
i dont think the plugs are gapp able and aslong as noone dropped the box the gap is preset
1991 xt6 eg33? 1993 gc track car |
The Bosch Platinum +2 and +4 plugs aren't "crap", I just don't think they are worth $12 each or whatever the heck they cost. Yes, I know iridium plugs are not cheap, but they last 90,000 miles, and in my opinion (especially if you are paying the dealer 3 hours to replace your spark plugs) it's worth the extra $ per plug, to not have to worry about it for 90,000 miles.
Remember that our cars are very picky about plug brand and material also.
My ebony had problems and wouldn't start for awhile......all because I put Autolites in it. It's back to NGK Iridiums and is running perfect. Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
I have ran bosch +4s running n/a for years and even with a 50 shot zex,but that was me also the svx calls for plat. but for my best,my best plug for nitrous was the regular cheap autolite nonresistor plugs,the reason for my choices was because I had an exhaust temp gauge installed in each manifold.
Platinum +4 have caused cold troubles in my SVXi. Cold idle and cold driving were hot/cold on power. The car just didn't want to run right. Since then I have only bought NGK BKR6EIX for any and all N/A SVXi. Anything running boost or N20 gets a BKR7EIX. Sorry, I know the SVX calls for a plat. plug but the iridiums run better, for longer.
Tom |
I currently have the +4s in... when I do change them, it will be the NGKs filling the hole.
-Mike ECUTune2v7 - 4.11 5 Speed - Sprung 6 Puck Clutch - D&S Rotors - SS Brake & Clutch Lines - HKS Panel Filter - HeaderBack Exhaust -80GB Hard Drive - GroupN Engine Mounts - - some other "tricks"
[SIGPIC][/SIGPIC] In progess: track down mystery noise <-identified, paint the new dash, get better pic Spring plans: Replace Trans - Integrate ECU with the carputer - Suspension - Go back to STI Filter - Paint? Maybe not - Next Oil change: Purolator L30165 Member #995 | My Locker | My New Locker Catch you next at: ? Auto-X ? |
Alright ! Spark Plugs changed, took me 2 1/2 hours but I feel better I'll post a picture of the Autolite that were in there . NGK Iridiums are in and I can say I don't feel hesitation like I did before.
2 1/2 hours?? I replaced mine this week. I used the standard recommended Platinum NGKs. It took me an hour though, but it was bloody difficult. Two and a half hours seems a long time, but I suppose it could take that long if you don't have the right tools. The plug sockets I use make the job very easy. I use two plug sockets plus extensions bought in Halfords. The reason for using two is the rubber insert. You need the rubber insert in place to extract the plug from the head. When replacing the new plug, you need the same size socket but no rubber insert, because when the new plug is tightened into place, you need the socket to retract when pulled. If the rubber gripper is in place it grips the plug tightly and you will just pull out the extension bar, which leaves you with the socket still on the plug deep in the head and a bit of a problem. With the correct equipment it takes an hour. If it is of interest I will take photos of the equipment and post it up. Joe
Two Sockets To Rule Them All. The plug sockets are relatively cheap. You buy two and use a needle-nosed pliers to extract the rubber sleeve from the Plug Install socket. That saves a lot of time. Joe
