My windows, power seat, and moon roof wont work.
The day I strarted the 5spd swap, the driver seat wondent move(that was annoying to take out), now that i am done with the swap The driver seat, the windows, and the moon roof wont move. I tried changing the fuse (SPF1) nothing happened. Any ideas? Thanks
there's also fuse 15 under the dash to consider, the window circuit breaker, and the ground under the driver's seat (for all three systems).
Were is the ground and the circut breaker? I am going to change fuse 15.
sorry, never had to look, just going by the info I have from Alldata.
Did you ever find fuse 15, and if you did, where did you find it?
Going to check fuse 15 today.
How do you find fuse 15, what is it listed as?
the fuses in the interior are numbered 1 through 21.
do you have the interior fuse box cover? To help oreintaye you, on my 92 model LS-L Fuse #1 is labeled Back/Turn, # 7 is R-Def, fuse #8 is labeled SRS Air Bag, #14 is EGI Unit/AT Unit, #15 is labeled Meter SRS Lamp, and finally #21 is Heater. See attached, the numbering is from the point of view of looking at the box, top left fuse is #1, others follow as in the diagram. Also see second page for how the electrical feed is used - two fuses for windows, etc. |
Checked and changed it and it dident solve it. Looked like the fuse had a good conection to no rust.
my advice is to check the grounds and power continuity.
you just need to go along the circuits and with a VOM, check for zero resistance to ground and 12-14 volts where it's supposed to be |
Do you have any idea were the grounds are?
never had to look, but under the driver's seat somewhere according to the manual, and several posts I've read on here. might try a search of two & see if anyone ever described the place - but I don't remember it if they did - of course my memory is (always has been) suspect.
