Old 06-07-2008, 08:01 AM
looking for ideas on no 3rd brake issue
Hey all,
So I bought a 'new' trans a little while ago and have been fighting allot off issues with it. One thing that has not been addressed by Mike is the lack of 3rd gear braking. In the many pm's I never received any thought from him on what could be causing this condition. I have read that not having the sol A resistor (behind the batt) connected will cause this. Well I have it plugged in and the resistance tested good also, even after a drive when it was heated a bit.
So, what else can cause a trans to have no engine brake effect while the shifter is positioned in the 3rd gear slot?
Any takers would be appreciated.
Thanks,
Shaun
blk 92' LSL w/ average mods
Old 06-07-2008, 11:40 AM
kwren's Avatar
kwren kwren is offline
I will be a taker!
Originally Posted by YourConfused View Post
Hey all,
Thanks,
Shaun
Simply take it back to the shop and get another transmission installed! Of course, it is in warranty
Have a great weekend!!!
Keith
Old 06-07-2008, 07:39 PM
Keith
here is the warranty: ()
Originally Posted by longassname View Post
If you break it in two you get both halves.
Old 06-07-2008, 10:12 PM
kwren's Avatar
Why no warrenty?
Old 06-08-2008, 12:27 AM
Back On Topic...
I am still wondering what could be the cause of no engine brake in 3rd gear.
Does the brake band have anything to do with it?
Anyone with ideas?
Old 06-09-2008, 11:13 PM
oab_au oab_au is offline
Hey all,
Thanks,
Shaun
I think your problem is related to the line pressure that has been increases when the the valve body was modified.
This raises problems with the Transfer clutch that can bind due to the higher pressure.
It also causes problems with the over-run clutch, because when the box is in D or 3rd position, the over-run clutch is not allowed to operate while the throttle is on or it will cause interlocking.
It knows this because it is looking at the line pressure, that it expects to drop to a set level to show that the throttle is closed.
This is the same pressure that the modification has raised, so it never gets to the set pressure that tells it that the throttle is closed and its OK to apply it.
One Arm Bloke.
Tell it like it is!
Old 06-09-2008, 11:45 PM
That sounds like a logical answer. Thanks for the input.
Old 06-10-2008, 12:17 AM
So this brings me to the question of where the transmission should shift. Due to the fact that the ecutune 2v7 chip raises red line to 7300 rpm should the transmission shift at that that rpm or at the stock 6K rpm? Or are there other factors in this game also?
Old 06-10-2008, 03:52 AM
It will still shift at the same speed as normal. 6500??
One Arm Bloke.
Tell it like it is!
Old 06-10-2008, 06:55 PM
Trevor's Avatar
Trevor Trevor is offline
Line pressure which is involved with the control of automatic shifting, is regulated by the TCU via solenoid A. The base line pressure, as could be affected by a mechanical modification, is regulated. The use of a bleed system is very affective in the instance off adjusting against increased pressures.
It could be argued that the regulated pressure could be raised on a percentage basis, but pulse length modulation of solenoid A and the time element, means that such would be minimal.
Trevor, New Zealand.
