Old 10-04-2007, 09:19 AM
CorSVXette's Avatar
Classic SVX
Rear Washer Fluid
I am having a problem with my rear washer fluid. I can hear the pump running when I try to spray the fluid but nothing comes out. ( and before you ask the obvious, YES I have fluid in the tank)
Old 10-04-2007, 09:35 AM
dcarrb dcarrb is offline
The hose is disconnected, or more likely the plastic connector is broken at the wiper end. Any fluid dripping from the trunk liner?
dcb
Old 10-04-2007, 03:29 PM
CorSVXette's Avatar
Classic SVX
dcb
No fluid dripping from the truck liner. I have to go out and try again but if I remember the last time I tried it it seemed to get a little wet at the end where the fluid is supposed to come out.
Old 10-04-2007, 03:40 PM
If the tube has not come off or the tip is not broken off, the hole may be plugged up. Look at the hole and see if it has some debris in it.
Old 10-05-2007, 01:58 PM
CorSVXette's Avatar
Classic SVX
OK I got some fluid to come out. There was a kink in the line. The fluid on shoots up maybe 1/4 the way up the window. Is that normal?
Old 10-05-2007, 02:47 PM
You can use a straight pin to aim the nozzle, but go easy. The first time I adjusted mine, it shot clear over the car.
dcb
