Old 04-02-2004, 08:47 AM
svxsubaru1's Avatar
How do you install camber bolts?
Ibought some camber bolts and was wondering how to install them, I tried last night but was unable to getthe washer thing put into the right position. Any ideas?
Old 04-02-2004, 09:17 AM
mbtoloczko's Avatar
sans SVX
The washer goes next to the bolt head. It takes a bit of jiggling (of the bolt and washer and strut and hub) to get the washer and bolt to seat flat against the strut. The position of the tab depends on whether positive or negative camber is desired. When setting the position of the washer, it may be necessary to rotate the bolt at the same time. Once you've positioned the washer, lightly snug the nut, and then the camber can be adjusted by rotating the bolt.
Mychailo
Visit my locker
Old 04-02-2004, 11:07 AM
svxsubaru1's Avatar
Do you know how to place the washer for negative camber.
Old 04-02-2004, 11:28 AM
mbtoloczko's Avatar
sans SVX
The little tab on the washer that sticks out at an angle points inboard for negative camber.
Mychailo
Visit my locker
Old 04-02-2004, 01:24 PM
svxsubaru1's Avatar
Thanks should the bent tab be completly parrel inboard? How much should thetab point inboard?
Old 04-02-2004, 02:41 PM
mbtoloczko's Avatar
sans SVX
It doesn't have to point perfectly straight inboard. It will only slightly affect the range of camber if its not pointing perfectly inboard. With that said, I've never had any problem setting the position of the washer. Are you having a problem getting aligning the tab?
Mychailo
Visit my locker
Old 04-02-2004, 03:16 PM
svxsubaru1's Avatar
I tried last night and couldent get the camber bolt to go in with the tab in and going to try right now sence its not extremly dark. Thanks alot for all the information .
Old 04-02-2004, 03:55 PM
mbtoloczko's Avatar
sans SVX
Try some different orientations of the bolt itself, but you do want the tab generally facing inward. Once you get it in there you can fine tune the position of both.
Mychailo
Visit my locker
Old 04-02-2004, 09:53 PM
svxsubaru1's Avatar
I installed them. I for got to disconect the sway bar, last night.
