Old 02-04-2006, 12:49 PM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
Power Steering Pump
It seems my power steering is going bad, making a whole bunch of noises. Well I want to replace it soon before I make a tight turn and all hell breaks loose Well, if anyone has a Power Steerin Pump for a 94 could you give me a PM or reply to this thread..thanks
Old 02-04-2006, 03:42 PM
What model?
L , LS or LSi ?
Old 02-04-2006, 05:44 PM
Before you replace the power steering pump, look in the How-To locker and see how to replace the O-ring. That will probably fix the problem that you have. It is only a dollar part, but will mess the whole system up if it allows air into it. Good luck.
Here is the link to the How-To.
Old 02-04-2006, 06:39 PM
Electrophil's Avatar
Electrophil Electrophil is offline
Which manual is "that" in??
I second "what Earl said".
Robert
Is Bush in jail yet? (Looks frantically at watch, then back up) How about now? Now? Come onnnnnn...... Someone freeze me until January, this wait is killing me.
Update: 09 January, and still not in jail! Wassup??
1992 Teal LS-L - 160k (Now new and improved with perfect paint!)
Old 02-04-2006, 10:03 PM
The pumps seldom fail, but the O-ring fails after 8 or more years. It will have lots of different symptoms. Give it a try first, it may save you lots of money.
Old 02-05-2006, 01:06 AM
AK Rowdy
Thanks for the replies...The model is LSi, but i think i am going to try the o ring first. Always best to save money Would a bad o ring cause a loud noise in the pump though?
Old 02-05-2006, 10:52 AM
Yes sir...
A usuall symtom of a bad o-ring is PS fluid puddleing on the top of the motor under the PS pump, it the top of your motor (under the intake) is wet it is for sure due to a bad PS O-Ring.
And it will make it noisey....
Old 02-05-2006, 12:17 PM
AK Rowdy
Well their isnt any puddling around the power steering pump, just really noisy when cold and randomly when i drive around for awhile.
Old 02-05-2006, 01:30 PM
It can be noisy, steering hard to turn, surge when you try to turn, fluid leaks, and many other not so good side affects. Let us know what you find out. I have found damaged ones to O-rings that aren't even there because they have been so bad. You will change out some of the tranny fluid at the same time which is also good to do from time to time.
Old 02-07-2006, 11:20 AM
AK Rowdy
Well the sound hasnt come back since yesterday,however the steering still seems to get tough to turn at times. Maybe it is the speed sensitive steering??? Or the pump does need to be replace
Old 02-07-2006, 11:32 AM
Either normal ops, or you are loosing hydraulic pressure somewhere... Or the pump is weak.
Robert
Old 02-07-2006, 11:12 PM
It takes some time to get all of the air out of it. Is your fluid topped off? One other thing that comes question. What fluid did you use? Power steering fluid, or tranny fluid? That might make a difference.
Old 02-08-2006, 12:24 AM
Ricochet's Avatar
Ricochet Ricochet is offline
I brought some ham.
Did you replace the O ring? I had all your symptoms thinking it was a bad pump.. replaced the O ring and it was fixed.
Brian
Old 02-08-2006, 07:58 AM
AK Rowdy
I used the recommended ATF Dextron...i read I wasnt suppose to use power steering fluid. To be honest, the sound was coming from the pump because the two torx bolts on top of the power steering resevoir were very loose...I was able to unscrew them by hand and Im guessing the sound was air coming in from the O ring not being tight. So I tightened them up and so far so good...no sounds or anything. Crossing my fingers
Old 02-08-2006, 08:23 AM
If they were loose, then the O-rings is toasted, or possiable completely gone....go ahead and replace the O-ring....it's only about 50 cents at your local parts place.
