rear housing swap 4.44
I currently have a 4.44. From a legacy gt and I'm wondering if the rear housing from my 3.54 with be a direct swap or even possibly beneficial for torque handling because of the extra clutch disc?
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
Re: rear housing swap 4.44
I learnt the hard way that you can't run a 4.44 transmission with a 3.9 rear diff. (We swapped the trans without knowing it was 4.44).
AFAIK, you can physically bolt in the 4.44 rear diff without modifying anything (ie no cutting etc), but you will wind up the centre diff causing shuddering and other nasty drive train stresses until something goes boom or you replace the standard transmission with a Legacy transmission. The Legacy transmission swap seems to be straight forward, again we just unbolted the blown SVX trans and bolted up a Legacy trans without any hassle. You should wait for someone more knowledgable than me to chime in before proceeding to pull your car apart though. |
Check this link out, courtesy of svxfiles signature.
Gene http://http://www.subaru-svx.net/forum/showpost.php?p=303945&postcount=6
He's talking about the transfer clutch and housing, not the rear differential.
Yes, it should be possible to swap over all associated parts including the housing from the stock SVX transmission. Though, I haven't personally done it. |
Pardon my ignorance 1986nate, is this an option to a straight 4.44 swap? Advantage and as feasible? I have done the full 4.44 swap.
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) Last edited by bwb3; 02-18-2013 at 05:10 PM. |
As you are increasing the torque capacity for the clutch by reducing the final drive ratio, it is not worth doing. Harvey.
