#376
Re: Individual Throttle Bodies and Improved Airflow
Hi Adam,
Due to the closeness of the throttle to the head it is changing direction going from a circular to oval to match the head. Your point about building a mould sounds good but I am not sure I can keep up with all the current projects I have infront of me now. But I would like to understand how I would do it so if you have any suggestions were I go to learn more I would appricate it. Tony
#377
Trying to post images
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by svxistentialist; 05-18-2011 at 02:23 PM. |
#378
The bit that does change things is the amount of taper or belling of the inlet end of the tube. If the ram tube is parallel with only a small flaring at the inlet end, the sound wave will do all the expanding at the end to give a strong but narrow pulse. if the inlet end has a lot of taper, the wave will start expanding as it travels up the taper, reflecting all the way. This gives a less intense, reflected pressure, that covers a wider rev range. It works the same as a megaphone on the exhaust. Also if the ram pipes are made out of a flexible material, the sound wave will diminish as it expands and contracts the pipe. Harvey.
#379
So how does length factor in here, my guess its all about the sound wave pulses and there ability to interfear with the airflow between valve openings. At low revs the time between sound pulse is greater so if the pipe is longer it takes that sound wave longer to travel along the pipe before it excapes the opening of the ram pipe, sound wave really are just air shock waves. Okay so your logic Harvey is that the mouth being larger at the opening is better is right if my tooth fairy logic is right. As the wave reaches the edge of the ram pipe it will slow down therefor giving the valve more time to open. If you imagine air inside the Ram pipe going into the engine then valve closes and the sound wave bounces back if it reachs the out let of the pipe before the valve opens it will stuff up the air going into the pipe. My guess is at that Point (harmonics) the engine will run like **** due to the disruption of air flow. Dumb question but if the sound wave is such a big issue why wouldn't you have the 2 vavles at slightly different opening and closing timing? Tony
#380
This will take a bit of answering mate.I'll get back later.
#381
**** Harvey I though you had the answer on the top of your head, just kidding.
I wonder if anyone in the SVX world has formula for airflow friction inside a small diameter pipe? Would be good to run some numbers over the pipe design. Also tooth fairy tells me if we know the airflow & velocity we might be able to rough calc the pipe as regards harmonics (problem just dreaming here). Tony
#382
This is interesting has a airflow simulation as well
http://www.epa.gov/eogapti1/bces/mod...y.htm#animate1 Check the difference duct shape example Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 05-18-2011 at 08:11 PM. |
#383
I finally got the ram pipes from the UK and they look great they will give a intake path length of 350mm and they start wide getting smaller as they go. I am pretty sure they won't meet Adams target tapper but they will be great to get started with. Here is a couple of photos.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 05-19-2011 at 04:55 AM. |
#384
Most certainly correct as the flexing of the pipe will alter the resonance of the wave. Composite(carbon) of appropriate weave, layering, and resin ratio will result in a ram pipe lighter and even more rigid than a comparable aluminum counterpart. The benefit of aluminum is off shelf availability as well as low cost. Building them out of composite eliminates any constaints prefab aluminum stacks leave you Quote:
The big thing with taper to remember is that it maintain laminar flow throughout the pipe. Air flowing down a pipe with straight walls creates turbulence in itself along the walls of the pipe due to a breakdown in the laminar flow. Many refer to this as a "boundary layer", which remains much more stationary than the flowing air at the core of the pipe. Air flowing over a layer of air has less friction and less turbulence than air just flowing over a surface They've got taper according to that picture, and in this case unknown taper is better than no taper Those look quite nice actually |
#385
There is a fair but of taper on them, so it will spread the resonate peak over a wider rpm range, than all arriving at the same rpm with a BANG.
The overall length at 350mm looks OK also. Harvey.
#386
I hope to get the injector ports and mounts sorted this weekend I have it mounted in the vice but I am having trouble with it moving due to the fact that its a fully adjustiable vice. Anyway I will figure a way around the problem.
HAve a good day all. Tony
#387
Mill a jig at the appropriate angle and mount in a single axis machinist vise or bolt directly to machine table with you part attached.. Compound machinist vises never have the rigidity required for this type of work and often require multiple repositions to complete the machining process, which is just a pain in the arse.
#388
You are right Adam its a pain and slow doing it in the tilt vice. Your idea of makeing a jig to put in the normal vice is smart I didn't think of that. As usal I am in a rush so I managed to get by with the tilt vice for now. Finished the first one and have the injector ports cut out. There is no doubt the 3d cad is the only way to go it makes it easier to do the job right the first time.
Here is a photo of the injectors test mounted. Next challange is the new mounting plate for the ram pipes I need then to bolt further to the side so I have more meat to drill the bolt into. Anyway it all foward motion. Have a great day. Tony
#389
Any ideas on how I should build the airbox, I was thinking of Aluminum but it may be a bit hard to make it rigid enough unless its pretty thick. The ideal world would be carbon fibre but I am not sure I can do it without build someform of mould first. Any suggestion greatly appricated.
Tony
#390
http://www.summitracing.com/parts/SUM-471500 http://www.summitracing.com/parts/SUM-471500 or maybe fab one simmilar to them but to the size you need |
