defrost is making clicking noise
friday i drove my car, used the defrost and it was fine. but saturday i went and started my car, turned on the defrost and now i hear a clicking noise once every second while it is on. the defrost seems to be working fine and if i turn off my defrost and use the other controls like regular heat circulating and everything and i hear no sound. just when i press the main defrost will i hear the clicking noise and it seems to be coming right from my steering column. any ideas what this could be?
Re: defrost is making clicking noise
Do u hear it in the AC mode also? Does it go away if you select economy mode?
no it is just for that one main defrost button. if i dont turn on that button than nothing makes a sound. but as soon as i use that defrost button i hear the clicking noise. its weird it worked fine the night before
I would suspect the "mode motor". It's located on the LH side of the heater box and it moves the air flow control flaps. Around one hundred bucks....
See attachement. Tapani |
perfect thank you. ill have to look into it with someone cause i dont know anything about it and how to read that drawing
Down load the AC part of the FSM from here:
http://phantomotaku.com/SVX/ The mode motor should throw a code too - the instructions for pulling the codes are in manual too. It is just a motor+plastic gearbox to move the flaps around. Close to the gas pedal. A bit tricky to swap, but I did it - you can do it too . Tapani |
just look up under your dash when you hear the clicking and feel around. you will be able to feel where it is coming from and if it has an electrical connector unplug it to see if it stops. this is common on small motors like this because a tooth will get worn down on the gear and sometimes it will continuously click as it spins one gear with good teeth past a gear with bad teeth that isn't moving.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
