Old 09-26-2009, 03:57 AM
viking64 viking64 is offline
warm start issues on replacement engine
Car starts fine when cold.
When warm / hot will start after 10 - 20 turns on starter.
After looking thru threads was looking to take sensors off old engine and replace onto this one.
Have cleaned MAF & changed rear temp sensors and thought all was well - still there.
The engine I'm using was from a 92 salvage and sat idle for 4 yrs I reckon.
Am I on the right track with doing the other sensors or try something else - Car runs fine once it's running - but really feels like it needs to turn over more than it should before it gets running, and I know they normally pretty robust and start straight away
- heading to post count 100!
Old 09-29-2009, 07:56 AM
Clydesvx Clydesvx is offline
Way over-the-hill Member
Re: warm start issues on replacement engine
I have had the same problem with mine. I have had many sensors replaced but it still has the same problem. Cold start no problem, warm start is a problem. I have found that one quick punch of the accelerator as it starts to crank seems to give it the ability to start when warm. More than one quick punch will flood the engine so be careful. Mine is a '92 but I don't know the year of the replacement engine. I have put almost 100,000 miles on the replacement engine and it has had the problem since day 1.
'92 LSL TEAL 277,000 miles
Trans (on # 3) Engine (on # 2)
"NEW" VISORS
'03 Forester XS 214,000 miles
'05 Outback 3.0R
Old 09-29-2009, 08:05 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Sounds like you might have a heat soak issue with the starter (?)
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-29-2009, 08:09 AM
Many starters, same problem.
"NEW" VISORS
'05 Outback 3.0R
Old 09-29-2009, 05:28 PM
oab_au oab_au is offline
Hi Mate. There are two main reasons that would cause the starting problem when hot.
First fuel, if if has a leaking injector, or a faulty temp sensor, it can be too rich to start first off, has to be cleared out to go.
The other one is the magnetic sensors like the crank,and cam position sensors. These age with time to lose some of the magnetic strength to produce a weak signal.
It may be strong enough to start when cold, but when they heat up the curie effect causes them to lose more magnetic strength, so that the signal is too weak to produce a constant signal, takes more turning for the ECU to trigger the injectors and spark.
Try swapping the ones out of the old engine, both cam and crank.
One Arm Bloke.
Tell it like it is!
Old 09-29-2009, 07:10 PM
update
progress has been made - will post here so it may help others (frustrating doing the searches and most are dead ends)
Installed the 2 cam & 1 crank sensors + 2 knock sensors.
Removed the alternator - then did it the hard way by leaving the plenum on to do the knock sensors.
All good - problem fixed. Looking at the removed sensors I'd guess the knock sensors were playing up when hot, other sensors were just dirty.
At least it was not the wire harness for the engine which I was dreading - it is quite hard and brittle.
Now starts first go every go - just like the maker intended.
Thanks for the inputs
bruce
Old 09-29-2009, 07:37 PM
Re: update
bruce
The magnets in the position sensors Will have the magnetic field shorted out by iron/steel filings across the face, can be cleaned and reused.
Looks like your problem, good work.
One Arm Bloke.
Tell it like it is!
Old 09-29-2009, 11:51 PM
AUSVX AUSVX is offline
Registered Loser
Hey I just changed the cam, cam and crank sensors, the car starts and drives so different now
Before:
Cold start - fine
Starting after immediately switching off - fine
Come back 2 or more hours later to start - engine turned over and over and over
My idle was low before, and now it's back up, my idle was at about 400rpm, at or below (in drive) the first line from 0 on the tachometer, the car vibrated because the idle was low, you could feel the fans kicking in and out and any rpm fluctuation SO ANNOYING!!
Now it's good as gold, idles at the 1st line below 1000rpm
I can take a picture of my old sensor if you like
Jordan.
Old 10-12-2009, 01:38 AM
appears problem is still there.
Cold Start - instant ignition
warm start - short stop - instant ignition
warm start - 20min stop or longer - very hard to start - 20 / 30 cranks
let car go cold - back to instant ignition.
so the fact if it cools down then starts indicates there is obviously fuel
could it be coils & H/T leads, weak earth somewhere when hot?
has to be something specific to this engine as previous engine was a well behaved one!
