More brakes......
The STi Brembo's are a swap for the WRX ('06-'07 TR's anyways). So what are the chances that we could use the '07 TR calipers? They are alittle smaller then the Brembo's so we may find something that works. I think the TR brakes are the same as the ver.V or VI JDM STi? Subaru 4pots.
Dustin
-Dustin 1992 Ebony LS-L w/191k miles Mods: a few and acouple more 1995 Brilliant Red L/AWD w/154k miles Mods: Stebro catback exhaust, K&N drop in filter, ECUtune ST1v5, 4.44, lots of JDM goodies 1992 Pearly LS-L w/154k miles Sold Mods: 4.11, rust 2008 DGM Legacy spec.B w/245k miles Mods: Cryotune Stage3, VF52, bushings galore, STi pink springs, Bilstein HDs My Locker The only man alive who drives three "Subu SVS's".......according to my insurance company |
What are you doing home at 10pm on a sat night? looser!
I was just getting ready to leave
Now its time for: "Working with a Hang-over"
Yay! HANGOVER WORK IS FUN!!!! just dont turn any lights on, or make any fast moves, or drop anything, aw hell go back to sleep!
-Chris '94 ebony pearl, with orange "silicone" hoses, painted beauty cover, Tom's Intake, Dayles Cold air intake; with HKS mega suction foam air filter, 3in header back exhaust, STI ground wires, euro front fascia, euro front grill, reactive 17in wheels, Nitto Invo's, Drilled and slotted rotors, stainless break lines, Koni strut inserts, Drop springs, 5MT, shotshifter, Clutchmasters clutch, ACT prolite flywheel, EL Glow gauges, The ECUTune stage 2. To Do: Cams, port and polish, etc. |
Believe me this stuff has all been discussed before... Search for brake upgrades and you'll find it... Short answer though - STi Brembo's bolt up to our cars but sit differently on our hubs so the STi rotors won't work. Solution? Have custom rotors made (good luck with that)... The "Subaru" red calipers would probably work with a bracket but then again, use a bracket and you'll probably need different rotors (since WRX brakes are smaller than ours)...
If you really want a set of aftermarket "multi-piston" brakes (and want to throw away alot of money) then go to http://www.revolutionbrake.com... There you'll find a few ready made kits for the SVX... I have only heard of one or two SVX's that have actually done it though... Try to remember, most of us that origionally started out looking to do an STi big brake swap gave up after seeing that the cost wouldn't really outweigh the benifit. It would cost too much to engineer the parts. It could be done no problem, but the cost of making the parts and the benifit that would come from it just doesn't make sense... Not to mention that if you just swap your pads, brake lines and rotors then you'll already have brakes that can stop you plenty fast. So do that, the Revolution Brake kit, or go down the road of fabrication. Either way it's kinda pointless to go asking about the impreza calipers and specs since most of us haven't dealt with them and wouldn't be able to give you FACTS. For facts on the calipers and specs them you'll need to go to a sight like NASIOC and find some brake guru's. Good luck... ~ Chris
2020 Subaru Outback Touring - Wife's first Subaru 2005 Volvo V70R - 5-cylinder love! :Heart: ** SOLD **1998 Subaru Legacy 2.5GT Wagon - MOST RELIABLE car I've ever owned ** SOLD **2006Subaru WRXSTi (Former "Boxer4Racing.com / Continential Tire" STi) - Built EJ22t block / EJ207 JDM STi "big port heads" - 9,000rpm MONEY PIT!!! ** SOLD ** 1995 "Tree-Hugger Green" SVX L AWD(5 MT) --- "Gumby" 130K miles #399 in MY95, my original love... |
p.s. hows the job search going?
Marisa '93 LSL Anniversary Edition - 02/93 - 150,998 Daily Driver - Forged EG33 (long block), 6MT swap, and re-upholstered interior '92 Pearl - 100k Side restoration project Locker | Old Locker | Shutterfly | ReadingIX | Facebook | Instagram |
Very interesting article in this month's Grassroots Motorsports on brake retrofits. Bottom line, if your current braking system can be put into anti-lock mode, then your rotors are big enough and your calipers are adequate. Obviously, whether or not you can do that depends on the tires you are running. If you are running 255 R-compound slicks, you might need more brakes. I'm running 245/40-17 Bridgestone RE01-R's (not quite R compound) and I can get into anti-lock mode (just barely). Changing the brake system (rotors and calipers) on the front only can throw off the braking balance for the car. Significant improvement can only be achieved if the stock front or rear brake system is significantly out of balance with the other end of the car.
Thermal mass (ability to absorb more heat for a given temperature rise) in the braking system (rotors and calipers) is really important for repetitive hard braking (the track). There is an obvious trade-off between braking system thermal mass and unsprung weight (it's all unsprung) related to handling. The SVX front calipers are medium sized, given that they are only 2 pistons. I also seem to be using similar braking points (closer in many cases) to other faster cars (of course, they're hauling it down from higher speeds). They pass me on the straight and I'm right back with them going into the corners. They then leave me in the dust exiting the corner. Don't go for drilled and slotted rotors. I have cracked a front drilled rotor all the way through one side wall (track overheating abuse). Get just slotted or dimpled and slotted. I'm running slotted Frozenrotors (cryo-treated). Even so, they show a pattern of hairline surface fractures from over-heating. Still going strong though. If you are suffering fade, your need to look at your brake fluid and your pads. I'm using ATE Super Blue fluid, and Axxis Ultimate front pads, Axxis Metalmasters rear (Ultimates not available for rear). I have never suffered significant fade at the race track, although I have glazed the pads (melted the surface). This reduces your braking potential slightly and makes a funny noise when you put on the brakes, but wears off after a short time. Also, you might look at rebuilding (or having rebuilt) your calipers. There is a good chance that age has caused their operation to deviate from spec.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
I'll jump in here and back this up about 98% here, with one crutch on the anti-lock theory being that initial bite on some setup may be enough to initiate the ABS sequence at low velocities but nowhere near enough once pad temperature comes up and ~75% of the rotors thermal capacity is met. My 965 had enough initial bite to initial antilock on stock rotors with PFB's in the calipers but ran out of thermal capacity up top. Upgraded to GT3 brakes with ceramic pistons and PFB's all around now to remedy that issue. Aside from that, one of the most solid informative posts on braking I've read in awhile. On a side note...........just in my opinion with dealing with my PCA/BMWCCA/Koni-GA race customers ditch that ATE super blue fluid. It's very hydroscopic and absorbs water vapor quite easily. It was common nature here to flush the system after every big race because that fluid would pull moisture and start to boil easily. Castrol SRF is what I run now, and although expensive I usually get a full season on one flush before it becomes water heavy and needs to go. I used to flush the ATE so much over the season I would easily exceed the cost of the SRF fluid. May not be the case in your situation or setup but just and FYI for you incase you start running into a soft pedal constantly. |
~ Chris
But maybe that was where we get screwed ('04 STi's are 5x100). I'll ask around and see whats up, maybe I can test fit some TR 4-pots. Dustin
