Screen Name Change...
Is there a way to change my screen name?I looked under quick link's,and saw how to edit everything else but the name.....
And what is with the avatar...it say's 100 by 100 pixels or 19kb I believe,I've tried to put up a pic that was 16kb and it wouldn't work.....what is it that I am not doing correctly?
Mike.... 8/96......Vin 100109 1997 LSI,18 inch Axis wheel(summer),16 inch ALT wheels(winter),Trans temp/Volt gauges,Iridium plug's, Autotechnica intake,silverstar high/low and fogs,polyurethane sway bar bushing's front and rear,Smallcar shift kit,Stebro exhaust finally..SWEET!! Motorsports drilled/slotted rotor's front and rear with ceramic pads and SS brake lines. 1997 SUS Legacy,finally got the engine in after a year!! My Locker www.myspace.com/devilhornz |
Mike
Your screen name can not be changed by you. It needs to be changed by an administrator. I will see if there is anything I can do for you because they have not been on much. As far as the avatar, it can not be any larger than 100 pix wide or tall. If you shrink it to that, it should work for you. If you still have problems, let me know and I will try to help you.
I changed mine.
what was your name before? |
If you'd like to have your name changed shoot me a PM with your desired new name and i'll execute the change.
Mike |
